01-21-2023, 09:03 PM | #222 |
all I do is test!
4622
Rep 996
Drives: I lost count of how many
Any info you can give me about the original image on your phone? Like the format (JPG, HEIC) or size?
Test 23456rt
01-21-2023, 10:21 PM | #224 |
all I do is test!
4622
Rep 996
Ok I just put a new release in the Play Store. It’s still called 5.5.4, but it is available now, try checking the play store to see if it lets you do an update. If not, it might take another hour to get to your local store, see if that version gives you as better image quality?
For sure the image quality was not great on the latest version, so I tweaked it and I saw an improvement on my test images
Test 23456rt
snareman10509.50 |
01-23-2023, 09:12 AM | #226 |
![]() 3515
Rep 3,981
5.5.4 working great! 🙏
On Order: 2025 Defender Octa // Charente Grey
Current: G82 M4 Comp xDrive // Frozen Deep Grey Current: 95B.1 Macan Turbo // Dark Blue Metallic |
02-03-2023, 11:22 AM | #227 |
Field Marshal
![]() 7453
Rep 2,042
Drives: '08 E92 M3
I found an issue (glitch) while using the App on my iPhone 8 (yeah I know it's old).. I'm including some screen shots to try and explain what happens.
Issue: When trying to type a post the screen area dedicated to text is limited by the App text formatting header and the iPhone keyboard. If one tries to write more text than can fit into the text write field then one gets locked into the writing field because one can not scroll down 'below or behind the keyboard. The scrolling function needs more than the space available or the cursor simply bounces back up above the keyboard. In other words, the scrolling feature only works above the keyboard and below the text header i.e. it isn't possible to see any text that has been written 'behind or below' the iPhone keyboard field. See images below. .
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive/BE Bearings & ARP Bolts/LUX H8 180/DCT Tune by BPM Sport/PFC Z-Rated Pads/ECS Brass Brake Caliper Guides/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium73656.50 apptest4621.50 |
02-03-2023, 10:09 PM | #228 | |
all I do is test!
4622
Rep 996
Test 23456rt
DrFerry7453.00 |
02-04-2023, 11:39 AM | #229 |
![]() ![]() ![]() ![]() 994
Rep 603
Drives: 2018 M2 6MT
apptest Here’s a strange one for ya. The iOS BIMMERPOST app shows a very long gray area below the post linked below. I’ve scrolled for a very looooong time and never found the end of the gray region. I think it was scrolling the whole time though, because it took just as long to scroll back up out of the gray region to the post.
https://www.bimmerpost.com/forums/sh...php?p=28903473 |
apptest4621.50 |
02-04-2023, 11:48 AM | #230 | |
all I do is test!
4622
Rep 996
Test 23456rt
jefe2000993.50 |
02-04-2023, 05:25 PM | #231 | |
all I do is test!
4622
Rep 996
Test 23456rt
jefe2000993.50 |
02-04-2023, 05:28 PM | #232 | |
all I do is test!
4622
Rep 996
I’m using it on an iPhone 8 right now and I can scroll this editor screen freely, meaning when the keyboard is covering my reply text, I can just scroll/swipe it up so that I can see the bottom of what I typed. Are you able to swipe it the text up so you can see the part of the text that is covered by a keyboard? ANd also want to confirm you are using 5.5.4, there was a much earlier version where scrolling was a problem, I think 5.2 or 5.3
Test 23456rt
02-04-2023, 05:37 PM | #233 | |
![]() ![]() ![]() 10760
Rep 6,420
Drives: 2022 Aventurin/SS G82 xDrive
02-04-2023, 05:47 PM | #234 |
all I do is test!
4622
Rep 996
You mean the endless grey area or not being able to scroll the post editor? (Endless grey area issue is confirmed bug and fixed)
Test 23456rt
'Cane10759.50 |
02-04-2023, 08:43 PM | #236 |
Field Marshal
![]() 7453
Rep 2,042
Drives: '08 E92 M3
apptest Ironically I tried replying to your post with your questions above being quoted, but the amount of text was too large a paragraph and I got trapped in the reply field and unable to scroll below the last few lines of your and mine quoted text. The text field header and text field reply block bump into the top of the screen if trying to scroll up and the field bumps into the keyboard when trying to scroll down. Like now I’m wwriting blind and can’t see what I’m typing.
///M Power-Belgium73656.50 M5Rick72552.00 |
02-04-2023, 08:45 PM | #237 | |
all I do is test!
4622
Rep 996
Test 23456rt
DrFerry7453.00 |
02-04-2023, 08:46 PM | #238 |
Field Marshal
![]() 7453
Rep 2,042
Drives: '08 E92 M3
apptest Okay 👍🏻
02-04-2023, 08:57 PM | #239 | |
Field Marshal
![]() 7453
Rep 2,042
Drives: '08 E92 M3
Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll. Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll. Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll. Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll. Oh look 👀 it’s working now. Nice and fast easy scrolling now. Well done. I still think the text formatting header is too large though. Do we really need the large “post a reply” label font and blue circle button? Those two alone take up 20% of the screen space not including the keyboard. . . . . . .
02-04-2023, 09:08 PM | #240 |
Field Marshal
![]() 7453
Rep 2,042
Drives: '08 E92 M3
apptest On the post I just made with quoted text, I just noticed the little arrow allowing users to unroll hidden text quoted went missing on my post and a couple of others close by. What causes the little unroll text feature to sometimes work and sometimes not? See image.
02-04-2023, 11:33 PM | #241 | |
all I do is test!
4622
Rep 996
Test 23456rt
DrFerry7453.00 |
02-05-2023, 08:59 AM | #242 |
Field Marshal
![]() 7453
Rep 2,042
Drives: '08 E92 M3
Thank you for taking the time to explain. I got to thinkin’ (which is always a little dangerous at my age), in the “old” App when replying to a post a box poped up without a formatting header taking up real estate. When posting using a browser only using “advanced mode” do text formatting options appear. I agree it’s an improvement and enhancement but perhaps improvement is subjective in the case of a phone app. By this I mean simplicity and elegance are also improvements. Just something to think 💭 about. Perhaps posting with the app could emulate the browser experience with a default simple plain text mode and also offer a “use advanced mode” button if users want to use the comprehensive text formatting header options? This would save space on smaller phone screens and perhaps simplify the default “post a reply” look 👀 and feel. Just my two cents..
