12-02-2015, 09:01 AM | #23 | |
Mlightened
![]() 1851
Rep 2,242
It can happen in any high horsepower car. |
12-02-2015, 09:18 AM | #24 |
![]() ![]() 5991
Rep 9,140
There is something about car shows/meets that makes 90% of the people that leave behave like 10 year old boys.... Perfect example here.
Alan
12-02-2015, 09:35 AM | #25 | |
![]() 218
Rep 1,161
12-02-2015, 09:44 AM | #26 | |
![]() ![]() 611
Rep 1,598
What can a driver do, when he get's in such an situation? Is there even anything that can be done? Countersteering isn't working as we have sadly seen at the shelby example... Braking also isn't working...see M4 reference... Maybe trying to do an 360 ( handbrake ), instead of trying to go straight? |
12-02-2015, 10:49 AM | #28 | |
![]() 2990
Rep 3,453
All sorts of idiots would ask me to "light em up" when I went past in my camaro. Right, like I'm going to toast $2000 worth of tires for you. |
12-02-2015, 11:36 AM | #30 |
Rather Ambivalent
![]() 384
Rep 755
Terrible driving on display. Too much throttle for too long, then not enough counter steering.
Such behavior is rampant among Mustang drivers. This is just another one with more power than skill. |
12-02-2015, 11:37 AM | #31 | |
![]() ![]() 113
Rep 378
OK cruising but when the power came on the rear got really squirrely and it was a handful. Just takes a pot hole or two to screw up the alignment.
ER CP, Forge DV, Wagner FMIC, PE, Maddad Mid, ER Sports OC, BMS OCC, RB Check Valve, AFE intake, Cobb AP3- Stage 1+ drive, BMW SS, PS Springs, Yellow Koni external, M3 Control Arms F & R, M3 Strut Brace, M3 Sub Bushing, Rouge Toe, Dinan Camber Plate and Rear Shock Mts., E93 M3 front sway bar, Mfactory Diff, Arc 8 PSS 235/40/18-265/35/18
12-02-2015, 12:05 PM | #33 | |
Mlightened
![]() 1851
Rep 2,242
There's a lot a driver can do, many people do this all the time and drive away looking "cool" as they burn out driving away. How many other cars before him did the same thing....the issue is this driver was not prepared or knowledgeable enough to control the car when the car broke traction then regained traction and he was unable or way too late and not enough road to correct the mistake. Counter steering does work, but you need quick reflexes, proper throttle application and space to correct the car's direction, braking also works, but usually not the best answer, but if you took a proper drivers class you would know that the tires can't do two things at once....they are either steering, accelerating(which sometimes involves steering i.e. awd cars), braking or loosing traction, neither of those can happen in conjunction, pick one. The driver in this video does not look like he even ever applied brakes, he mashed the throttle, lost traction, car spun, I don't even see any steering input, and he kept accelerating or maybe just lifted off at the point when he noticed an imminent collision. (I am not an expert, and my very basic assessment is an opinion lacking facts or clear knowledge of exactly what went wrong, it may in fact be the gas pedal broke and got stuck, or steering wheel broke, or a bee stung him below his eye, who knows...) Trying to do a 360 degree handbrake...wtf....this is not the movies...perhaps if that were your plan all along but not in the middle of an unplanned accident. There is plenty you can do to prevent this from happening, first it begins with the obvious, do not be an irresponsible assclown on public roadways with people around, and if you are going to do it, you need to know how to control a car under these circumstances. Again, at a drivers course they will put you on a wet course and make you loose traction so you can learn to control the car, like sort of drifting and how to regain control, usually it involves lifting off the throttle and feeding in the correct steering inputs. Look at a video of Chris Harris behind the wheel when he brakes traction and lights up the tires, the steering wheel is going left/right-right/left or vice versa making split second corrections....looks easy but it's really not, thats why the above video, know wut em sayin... ![]() |
12-02-2015, 01:16 PM | #34 | |
Rather Ambivalent
![]() 384
Rep 755
"...the tire can't do two things at once.." This is not true. In an AWD car, the front tires are acceleration and turning at the same time. In any car the front tires can be decelerating and turning at the same time. A better way to word what you are trying to say is that tires only have 100% of traction available, and the more things they are doing- acceleration, decelerating, turning- the less traction is available for each of those tasks. A car accelerating in a straight line has 100% of it's traction available for the task. When accelerating out of a turn, that grip is being divided by two tasks- forward grip, and lateral grip. |
12-02-2015, 01:31 PM | #36 | |
![]() ![]() 2051
Rep 8,339
Falls into it can't do two things at once. If they weren't braking or acceleration, the tires would have, wait for it, been able to steer. |
12-02-2015, 01:52 PM | #37 |
Rather Ambivalent
![]() 384
Rep 755
This notion that cars or their tires can't do multiple things at once needs to be discarded. It's not true, and keeps one from fully understanding the dynamics of a car, and it's handling characteristics. I don't where that idea even comes from.
12-02-2015, 01:56 PM | #38 |
![]() ![]() 2051
Rep 8,339
What should be inserted in the statement is "well". Tires can only do one thing at a time well.
12-02-2015, 02:00 PM | #39 |
Rather Ambivalent
![]() 384
Rep 755
While less incorrect, that is also not a concise, definitive way to put it. It depends on the tire, what it's on, and conditions. As I said earlier, a tire only has 100% traction at any given time. The more tasks that traction is being split up into, the less traction for those respective tasks.
12-02-2015, 02:04 PM | #40 | |
![]() ![]() 2051
Rep 8,339
12-02-2015, 08:25 PM | #41 |
![]() 540
Rep 145
well its obvious the guy has bad judgement skills looking at those rims... good God those things are hideous... Sticking those on the car made it go into self destruct mode I guess....
12-02-2015, 08:39 PM | #42 |
dances with roads
5248
Rep 4,145
I'm not sure which is more entertaining - the video, or the descriptions here of what went wrong and what could be done about it.
12-02-2015, 09:33 PM | #43 |
I know a thing or 2 about a thing or 2...
3164
Rep 3,501
Drives: E36 M3 Coupe, e39 M5, G26 i4
Seriously, idiots like this need to have their licenses suspended for a minimum of a year.
2025 i4 eDrive40 Tanzanite Blue
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold) 2014 Carbon Black 650i M-sport (sold) |
12-02-2015, 09:35 PM | #44 |
![]() ![]() ![]() ![]() 20011
Rep 19,312
Enthusiasm > than driving talent. Simple.
The car is not at fault here.
