09-06-2008, 08:47 PM | #23 |
![]() ![]() 399
Rep 2,526
You''ll find that increasing the ISO makes your pictures grainy, and vice-versa - I think that's what the person was trying to get at, but if you don't have something stable for your camera to sit on, having a low ISO will result in blurry pictures. I'm not sure if the D40 has this setting, but on the D60 there is a "Noise Reduction" setting which removes a little of the grain.
Increasing your ISO will also allow you to shoot at a faster shutter speed, reducing blur but increasing noise simultaneously. Try it ![]() After you get used to how your camera shoots under certain conditions, adjust the shutter speed and ISO together to get the least blurry and least grainy picture. I'm wondering if the person who told you to leave the ISO as low as possible is talking about normal, well-lit, conditions, or under dim light? |
09-07-2008, 02:21 AM | #24 |
![]() 50
Rep 1,664
D40x has the noise reduction. Just tried some high ISO shots in low light, they came out great. Keeping the camera stable was the toughest part. I tried a night shot focused on a star, at 1600 ISO was able to see others stars not visible with the naked eye. The entire sky lit up.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
09-10-2008, 09:57 AM | #25 |
e90 newbie
38
Rep 448
tips on shooting in low light:
1. Get the right lens - Buy a fixed 50MM F1.8 or 1.4 lens. This lens will work 4-8 times better at shooting in low light than the kit lenses that most cameras come with. 2. Set ISO higher to 400 or 800. Graininess should not come into play until higher than 1600. 3. Tripod the camera 4. If you really have the time, set the shutter speed longer - open the shutter for a longer time to get more light (Everything has to be perfectly still) Good luck
E93 IL Blue M3 ZPP, ZCW
