07-14-2010, 12:56 AM | #23 | |
![]() ![]() 645
Rep 1,753
It runs silent (unless the cooling fan kicks on), is more immune to abuse (as most laptops are subjected to, compared to a desktop), it's snappy on start-up and application launch. Yes, a draw back is over a time frame it will loss cells, but it will still last long enough over what the average life span of a laptop is. As long as you backup (which I do via time capsule daily), if it does die before replacement time, just get a new SSD and do a restore from back-up overnight and it's like nothing happened since time capsule takes a complete image (including settings) For me (for a laptop) the pros out weigh the cons.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels) 15' Audi S4 13' Audi TTRS (APR stage 1, MSS springs) 09' C6 Z06 08' M3 Interlagos Blue: 6sp, Tech. |
07-14-2010, 12:58 AM | #24 | ||||||
you know he kills little girls like you
![]() 403
Rep 892
http://www.xbitlabs.com/news/storage...te_Drives.html Honestly though, this does not speak to how long the drive will last as that will depend largely on utilization. Quote:
Your overall performance will probably not be better with 2 15k RPM HDD that it will with one SDD. I'm not sure what would make you say that. Even the slowest flash is almost an order of magnitude faster than 15k RPM HDD for random access, and still 1.5 to 2.5 times faster for large sequential access. Any NAND drive will outperform a 7.2k RPM drive, easily. It wouldn't even be a competition. Last edited by radix; 07-14-2010 at 02:12 AM.. |
07-14-2010, 01:57 AM | #25 |
![]() 403
Rep 892
http://www.thebuzzmedia.com/intel-x2...nchmarks/#iops
Price: $404: http://www.newegg.com/Product/Produc...82E16820167017 Price: $190 x 2 = $380: http://www.newegg.com/Product/Produc...heetah%2015k.6 So for $404 dollar you could get one SSD drive that would probably out perform two HDDs in a RAID-0 configuration. On the other hand, you'd get less about half the usable storage space. Keep in mind that if you're running two drives in a RAID-0 configuration, you have to divide the MTBF for one drive by two. x = number of drives y = mtbf for drive n = mtbf for array n = y / x In this case x would be 2, so n = y / 2. Since you're in an unprotected configuration, loss of either drive will result in the loss of data. Last edited by radix; 07-14-2010 at 02:09 AM.. |
07-14-2010, 02:39 AM | #26 | |
![]() 403
Rep 892
07-14-2010, 10:20 AM | #27 |
![]() 1092
Rep 1,268
radix,
Did not want to try and respond to each of your points in quotes, however it is obvious you are familiar with the technology, I am too. I Manage mass storage technology for a large company and I use to working as an engineer in a very well known computer company doing drive qualifications as one of my jobs. No SSD today is using NAND flash with 10K write and erase cycles those were based on 56nm technology which were taken off line last years by all the manufactures Toshiba being the last. Today they are all shipping 34nm technology and it has 3K cycles, and they are moving to 2Xnm technology next year it will have 1.5K. You mention the eMLC as having 30K, which it true but the way they are achieving this is by slowing the device down, there is more to it than that but that is the basic approach which mean the it will not preform as well. Another important point with SSD, they should not be spec on write and erase cycles which they had avoided talking about but will share if asked, they should be spec on total GB transfer and still maintain specifications. I been asking for this for years and they are now specing the SSD this way and you would be surprised. Basically, you can transfer so much data and then the device starts to drop in performance or it is wore out can not be use, not the case with HDDs time and POH is the limiting factor on HDD but not how many bits you can write. Imagine if every car on the road stopped working at 100K miles not to be fix or usable, that is what you get with SSD. Also the links you list are Intel propaganda and I will it at that. Your correct HDD have blocks that fail, and the HDD moves data around and spare the blocks out and some times you get an unrecoverable error, just the fact of life with HDDs, but HDD do not wear out like SSD do. You can write a block on an HDD millions of times and it will not degrade just because of the bits being flipped. What I mean by erasing data is the SSD as part of their wear leveling algorithms move data around to all the cells and every time it changes the data or flips the bit in a cell it is a write and erase cycle. Also as the OS creates and deletes scratch and temporary file this adds to this problem. Now on performance, I personally have not see any data from any manufacture demonstrating the performance of their SDD over time, as it is worn, as it is filled to capacity. I have asked for it from Intel, Toshiba, SanDisk, Samsung, and Micron, oh by the way Intel uses Micron Flash and none of them can backup their claims other than how it performs new out of the box. NAND Flash is dying as an industry, unless they can solve the data reliability problem, it will continue to useful in products like MP3s but any device that has what is called data turnover can not use it beyond the current technologies. nTo all SSD are the same, there are only 4 companies who make Flash and 50 companies making SSD, some have a clue and most have no idea what they are doing. Personally, buying SSD from companies like WD, Seagate or Toshiba is good since they understand the entire storage industry and understand data integrity issue due to their 30 years of HDD experience. Everyone else is just trying to sell you a product. I am not saying SSD are bad, I am saying it depends on the application and that most consumers have no clue about it. They see and hear all the great things about SSDs, but much of it is based on SLC technologies, drives that use a combination of SLC and MLC technologies or also incorporate SDRAM. Yes you can get 64GB SDD in the $150 price range but it does not have the performance you think, you are going to be spending more like $500 to $1000 for high performing SSD that can keep up with a server class drive you showed. I personally rather use a HDD with a back up than spend 3X on a SSD and then buy a HDD to back up still. Last edited by Maestro; 07-14-2010 at 10:32 AM.. |
07-14-2010, 01:48 PM | #28 |
![]() ![]() 266
Rep 4,279
I don't want to pay $600 for a 256GB drive, regardless of it's efficiency, NVH or speed. As with everything, wait till it proliferates. Companies are not really thankful to early adopters.
07-14-2010, 03:32 PM | #29 | |||
![]() 403
Rep 892
Even at 3000 write cycles, it's still not that big an issue, here's how the math works for a 160GB drive: Quote:
http://techon.nikkeibp.co.jp/article...090528/170920/ AFAICT, the 1.5 number is probably the product of coefficients for both wear leveling and write amplification, if I had to guess. Nevertheless, that's 22 years for a drive with a write endurance of 3k per cell for a user that writes 40GBs of data per day. http://techreport.com/articles.x/15433 Quote:
