      11-23-2011, 09:29 PM   #23
///Chris
9
33
Drives: '07 328xi
He may be confusing his theory with the fact that if you double a car's HP, it will not actually be twice as fast
      11-23-2011, 11:31 PM   #24
abisson
Canada FTW.
abisson's Avatar
196
519
Drives: 2016 VW R - Stg 2
Originally Posted by carve View Post
The output of two identical 300 hp engines is 600hp unless you somehow have them geared to a common output shaft that isn't in line with the other two output shafts. Then you might have a little gearing loss. That isn't generally the case in boats- they usually have their own props.
Read posts above this one. I said some factors would not make the things the same.
      11-24-2011, 12:50 AM   #25
carve
carve's Avatar
190
1,105
Drives: 335i
What factors would not make the output of two identical 300 hp engines equal 600 hp?
      11-24-2011, 12:54 AM   #26
1speedbike
1speedbike's Avatar
745
3,284
Drives: 2022 X4 M40i, 2008 135i
It's not so much the horsepower, but the torque that matters. However, since the horsepower and torque output of a specific engine are pretty much tied together, it makes little difference.
Torque is measured in ft lbs for a reason. It is a measure of rotational force, and this rotational force is transferred into a translational force when the spinning propeller of the engine pushes against the water. The propeller will create a force on the water and (by Newton's Third Law), the water will create a counter-force on the boat.
This is what pushes the boat forward. Torque is additive, and only the NET torque in a particular direction matters, so one 100 hp motor going north is the same as two 50 hp motors going north, is the same as one 150 hp motor going north with one 50 hp motor going south, is the same as one 70.71 hp motor going northeast and one 70.71 hp motor going northwest. This is all assuming that the motors are operating at an equal power output the whole time, are indeed identical, and the motions of one aren't affecting anything about the other.
2022 X4 M40i - 2008 135i - 2015 F700GS
On Order - 2024 i4 M50
Scruffy's gonna die the way he lived... Mmhm.
      11-24-2011, 01:58 AM   #27
schoy
997
1,003
Drives: Melbourne Red E90 M3
2 300-hp engines will produce 600 hp in terms of capacity. How that 600 hp ends up being used (losses, etc.) is a different story.
      11-24-2011, 02:26 AM   #28
E90SLAM
Supreme Allied Commander
E90SLAM's Avatar
Hong Kong
2016
61,781
Drives: A BBS WHORE
Ask Jeremy Clarkson on his amphibious car project...
      11-24-2011, 02:32 AM   #29
Brey335i
118
4,771
Drives: e46 ///M3
I've done a couple of boat projects and I want to chime in with something here. It's not just about weight and combined horsepower, but two propellers each driven by it's own motor is going to be more capable than one similar sized propeller powered by a twice as powerful motor. Think of it like stuffing 500 hp in a car with some 195 tires...
      11-24-2011, 02:36 AM   #30
AllydNYC
Loading...
AllydNYC's Avatar
359
2,187
Drives: 91' E30 318is
1991 BMW 318is  [0.00]
Originally Posted by NYCGP View Post
      11-24-2011, 08:57 AM   #31
achien
AC
95
2,387
Drives: E90 Post Members Crazy
+1, specifically, aerospace engineering. They will teach you the difference in various factors of having one engine plane, two-engines-plane, or four-engines-plane. Not to mention the gravitational force derived from weight of the plane, drag co-efficient derived from aerodynamics of the plane.
In your case of a boat, you will study fluid-dynamics and the drag co-efficient of the boat.
Please take your friend back to school.
Originally Posted by jokergerm View Post
I have been arguing with a friend that 2, 300hp engines is the same HP as one 600hp engine
He thinks that 2, 300 HP engines would only be about 450hp
Originally Posted by immiketoo View Post
Wow. You need new friends. I'd suggest looking in the engineering department at your local college.
Your Supreme Leader
      11-24-2011, 12:34 PM   #32
carve
carve's Avatar
190
1,105
Drives: 335i
That's surprising. It seems like you could adjust the pitch and prop speed to make either work fine. I could see how a big prop might cavitate or have excessive tip speed if you tried to turn it at the same rpm...but you'd want to turn a big prop slower but with greater pitch. Sounds like it's probably just a practicality issue.
      11-24-2011, 09:12 PM   #33
The1
76
5,114
Drives: white 135
I own 2 boats and both are twin engined, just because they have totals of 540 and 770hp, does not mean they will act like they do.
having 2 engines is more for torque and outright power as well as hull shot. a single 600hp engine in the dead center of the boat will be able to lift the boat higher out of the water resulting in more speed.
so a single engine can actually be quicker in some cases depending on application.
this is why some of the bigger formulas and dozi boats have offset motors, they get the drives closer together resulting in getting the drives closer to center on the boat, and acting closer to being more like a single engine. But it's still not 100%
also keep in mind, a second motor adds between 100 and 1000lbs to the boat, slowing the boat down
rotation of the props also has an effect, will one of the props be counter rotatating?
long story short, 600 horsepower is 600 horsepower no matter how you look at it or put it together eg, 6x100hp or whatever, but it's how it handles the power that makes all the difference.
does this help? I can try and clarify more.
      11-24-2011, 09:15 PM   #34
The1
76
5,114
Drives: white 135
counter rotation on one engine can result in less power at the prop, but the engine is still 300hp either way
just like how a car engine can be 300hp, but at the wheels it's 270 due to loss.
counter rotating drives are pretty uncommon on boats however.
      11-25-2011, 12:28 AM   #35
jokergerm
132
571
Drives: 2015 M6 GC
Ya it helped a lot thanks
      11-25-2011, 02:10 AM   #36
The1
76
5,114
Drives: white 135
no worries.
      11-26-2011, 12:53 AM   #37
thetedderbear
thetedderbear's Avatar
77
632
Drives: Fiesta ST
This is my second time reading this thread. Up until just now I was really confused as to how 2,300hp equaled either 600 or 450 ponies
      11-26-2011, 12:47 PM   #38
chungdae
The Asian Sensation
chungdae's Avatar
59
708
Drives: 2009 Alpine White M3, S1000RR
You really need new friends. Preferably friends that do not do drugs nor drink alcohol heavily.
2001 Audi S4: RIP
2008, Infiniti G37S: Traded
2009 Honda CBR1000RR Sold
2009 BMW M3: Current
2011 BMW S1000RR: Current
      12-02-2011, 12:29 AM   #39
TroyDeJ
84
984
Drives: around aimlessly
if your talking at the crank than they would equal 600hp but at the prop they would come close to 600 but not exactly. A 600hp outboard factors in drivetrain loss once as twin 300hp outboards factor in that same loss twice resulting in slightly less final output HP
      12-02-2011, 12:27 PM   #40
The1
76
5,114
Drives: white 135
but 1 600hp engine is going to have the same drivetrain loses, so it's going to work out fairly similarly in the end either way, so this does not apply.
besides, let's say it's a 10% loss on the 600hp (it will be less then that but i'm making this easy for people) the 600 would lose 60hp
the drives on the 300hp engines will have a similar if not the same loss, so it would be 30 per engine which will add up to 60hp again, so you're in the exact same situation again.
so unless the OP specifies that the 600hp engine is power at the crank and the 2 300hp motors are at the prop, then there will be no real differences.
      12-02-2011, 12:31 PM   #41
TroyDeJ
84
984
^true i didnt bother to do any kind of math in my head because it was 1:00 when i posted that haha
      12-02-2011, 12:31 PM   #42
The1
76
5,114
Drives: white 135
haha, no worries.
      12-02-2011, 02:33 PM   #43
kyleb350
kyleb350's Avatar
429
4,709
Drives: '21 X3MC
Not sure how this thread got to drivetrain loss. The question was referring to the engines only; plus, boat drivetrains are much simpler. 300 + 300 = 600
