01-31-2020, 10:24 PM | #6909 |
2006 TIME Person Of The Year
9705
Rep 6,445
This longtime Lactaid devotee may have just found his new milk of preference. I bought mine at Whole Foods.
02-01-2020, 12:28 PM | #6910 | |
Schmollbraten
12482
Rep 1,985
To explain you my rating: Aside of its very cool design and art, its way much too big and unhandy to use it for more as just the head. The adjustment, memory and floating stageadjustments are just annoying after switching it on. You hit the power button and rest your thumb automatically onto the sensorfield, where the length is be set...brrrrt, the length changes instantly. So you have to reset it onto your desired length or use the memory function. Second and for me most important reason: The 3 delivered combs are all way too big and from the design are not really useful to clip all kinds of headshapes at the first try. Reason herefore are the cutdesign, the comb rests into the housing and the length is adjusted from the machine. The cutting zone is in the middle of the comb and when you start clipping, the cutzone must be plain and straight, otherwise the blades wont cut your hairs to the desired length. Had started at the read lower side of my head and try to make the closer corner to my main head...no way. Within the "curve" I'd lifted the comb a bit and all hairs weren't hit properly, so I had to treat that place over and over again, until the last hairs were cut. Whats more to say? The hairs are starting to stuck under the comb dorsal end to the machine and you have to wipe or blow out them more than one time, depends on your hairthickness. But the most disadvantage is the unusability at other parts at my body, starting into my pits, caused by the comb and cutter design, its impossible to reach all hairs into the pit, you can't turn your pit into a flawless plain area. Same at chestparts and so on. You may consider my words, when you're gonna buy exactly this machine. Maybe its fitting better for you, but I will definitely looking for another one.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
Dog Face Pony Soldier9704.50 King Rudi13072.00 |
02-01-2020, 01:34 PM | #6911 | |
1106
Rep 1,440
There are other hair cutting tools for other then the "top" of the head parts of the body (including nose/ears, moustache/beard separately from the hair). Once it's Philips you chose, here you are (their range): https://www.usa.philips.com/c-e/mens...g-welcome.html. And yes, a Philips hair clipper (a simpler model, same design) does fail to follow the head shape any nicely, "expecting" it to be perfectly round, at least, if not just flat. Yet other manufacturers' (I haven't tried yet) look quite the same in appearance. |
02-01-2020, 08:06 PM | #6912 |
Schmollbraten
12482
Rep 1,985
Hence you dont know my previous clipper model, which was also a Philps, it was useable for all, I was expecting same possibilities and for sure I know that there are different models for different purposes. But nice sideeffect that my story gaves you a chuckle.
02-01-2020, 08:18 PM | #6913 |
9705
Rep 6,445
My resistance band collection has outgrown my makeshift storage solution. Time for a proper hanger. Rogue's 5" deep version is perfect for the space I'm allocating.
02-02-2020, 10:55 AM | #6914 |
1106
Rep 1,440
Using a single, non-dedicated tool, like an axe , for all your grooming needs seems a bit outdated. If you wish to shave your groin, in particular.
02-02-2020, 10:12 PM | #6915 |
668
Rep 767
Got myself a turntable... love me some vinyl
02-03-2020, 02:44 AM | #6916 |
Schmollbraten
12482
Rep 1,985
Does it have an USB cable, makes digitalizing more easier, if you consider this.
02-03-2020, 05:13 AM | #6917 |
Schmollbraten
12482
Rep 1,985
Finally get a carbon diffusor for my car, as good as new, replaces the glossy black one.
02-05-2020, 03:32 PM | #6918 |
I'll get back to you
7535
Rep 2,132
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
02-14-2020, 06:22 AM | #6921 |
8203
Rep 2,250
I love their shirts and have been buying from them since their first commercials.
Everybody has a gameplan....until they get punched in the mouth.
02-14-2020, 10:10 AM | #6922 |
3227
Rep 2,385
New old car.
13
Violator4593.50 nyalpine907551.50 spazzyfry1235033.00 RickFLM411858.00 lsturbointeg9201.50 Dpc2u11490.50 bobowar1353462.00 Burnsey328.50 Red Bread4458.00 TXSTYLE15027.50 Dang3r12481.50 wrickem2143.50 Turkish Pickle3057.50 |
02-14-2020, 10:31 AM | #6923 |
5729
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
Got tired of getting the pressure washer out to wash the car so I got this Chemical guys foam canon that uses the garden hose. It's less foam but soo much easier
02-14-2020, 07:40 PM | #6924 |
5033
Rep 1,984
Drives: Here and There
Garage List (2)11 BMW E90M Stri ... [10.00]
(1)11 BMW E90M Stri ... [10.00] 98 Lexus LS400 [10.00] 16 Toyota Land Cruiser [10.00] 97 Toyota Land Cruiser [8.33] |
dinonz3227.00 |
02-15-2020, 04:04 PM | #6926 |
11820
Rep 23,186
Secrid in vintage brown and ridge in od.
Ickdeep5729.00 NorthCountryGuy1682.00 |
02-15-2020, 05:49 PM | #6927 |
11491
Rep 1,065
Finally broke down and got this-
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
02-15-2020, 05:50 PM | #6928 |
Remove Before Flight
7736
Rep 1,646
02-15-2020, 07:39 PM | #6930 |
"Salud"
15028
Rep 4,919
Drives: M8 Gran Coupe Comp & X5M Comp
Valentines Day gifts His & Hers...
Watch she wanted: And some cologne she got me:
