04-21-2021, 03:47 PM | #1145 |
7014
Rep 3,313
We went from old school granite to a very reputable brand of man made quartz and the granite absolutely SHITS all over it. Granite is far less likely to stain and is far harder, wife already chipped the quartz.
04-21-2021, 10:53 PM | #1146 | |
Not willing to take advice
4670
Rep 1,576
If you're having chipping issues, staining, or can't set a hot pan on it...you don't have quartz. |
04-22-2021, 07:33 AM | #1147 |
11916
Rep 4,875
Agree that quartz is harder and nonporous so less likely to stain, but granite is more heat tolerant. You don’t want to place a hot pan directly on quartz.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 Last edited by RickFLM4; 04-23-2021 at 10:04 AM.. |
04-22-2021, 08:41 AM | #1148 |
7014
Rep 3,313
04-22-2021, 08:53 AM | #1149 |
16946
Rep 2,092
Drives: 2022 X6///M Comp
Found this online.
The biggest difference between quartz and quartzite is that quartz is a man-made material, while quartzite is a natural stone. A quartzite countertop begins as sandstone, which under a natural process of heat and pressure is fused with sparkly quartz crystals to form quartzite. Quartzite typically comes in shades of white or light grey, but minerals in the stone can lend pink, gold, or reddish-brown hues. A quartz countertop is engineered with the same quartz crystals found in quartzite, but a man-made process binds the crystal with resins, pigments, and other materials such as bits of glass. This process results in a very durable, non-porous countertop material that comes in a wide variety of colors and designs. Aside from the different composition of these two materials, the stylistic differences are quite striking as well. Quartzite is often mistaken for marble or granite, as it has the delicate veining of marble and similar coloration and patterning to some granites. Those seeking a natural look with lots of movement may prefer a quartzite countertop. Quartz on the other hand, can be made to look like any stone, and is offered in many different shades and patterns. If you have a specific color in mind, or want a consistent pattern throughout your slab, a quartz countertop is probably a better bet for your home. Another big difference between quartz and quartzite is the care routine and durability of each material. The binding process makes quartz extremely durable as it helps to extract air, making quartz a hard surface that is non-porous, and therefore resistant to chipping, scratching, and bacteria. Quartzite is a fairly hard stone, but it's less dense than quartz and susceptible to easily staining in a heavy use area such as the kitchen. Quartzite requires sealing to prevent staining the surface, while quartz needs virtually no maintenance.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
04-22-2021, 01:33 PM | #1150 |
Space Force - 4 Star General
11505
Rep 3,265
Anyone else here stunned by the costs of raw materials, especially lumber? I'm constructing a small "shed" to store and season split firewood. Making it mostly out of cedar, repurposed from a fence I tore down. I need a couple of 2x6 for the rafters and some plywood for the roof sheathing. 2x6 cedar is $11 a linear foot and 1/2" doug fir ply is $60 a sheet! WFT?! Guess I'm using pressure treated 2x6 and OSB chipboard for the roof. Sheesh.
04-22-2021, 02:16 PM | #1151 | |
13077
Rep 1,965
DETRoadster11505.00 Buug95924057.00 |
04-22-2021, 02:26 PM | #1152 |
4781
Rep 1,189
04-22-2021, 02:29 PM | #1153 |
Recovering Perfectionist
21708
Rep 1,024
There was a story on our local TV news this week about wood shortages from the COVID construction and home improvement project boom adding $25K to the cost of new houses these days. If memory serves me correctly, the demand for lumber was up 70% and pushing the prices up.....
Currently BMW-less.
04-22-2021, 02:37 PM | #1154 | |
7699
Rep 1,264
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
9
MPOWER52664781.00 DETRoadster11505.00 King Rudi13077.00 RickFLM411916.00 Marmugmotleocay1805.50 E92 M Sport285.00 S1nner159.00 jmack548.50 |
04-22-2021, 04:39 PM | #1155 | |
594
Rep 145
I just replaced a 55’ section of fence that the wind blew down, and it cost me 2x as much as the 110’ section I replaced 8 years ago.
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
04-22-2021, 05:13 PM | #1156 | |
24057
Rep 892
Wha' da ya mean? No brakes never stopped anyone before!
DETRoadster11505.00 |
04-22-2021, 07:04 PM | #1157 | ||
11505
Rep 3,265
04-22-2021, 07:38 PM | #1158 |
24057
Rep 892
The plus side is that you have the land. Something to consider though happened to me years ago. I bought a large lot, about 4.5 acres, and sat on it for a few years before building. The problem I ran into was nobody wanted to give me a mortgage because I owned the land outright. They didn't want to be holding a mortgage without claim to the land the house was sitting on. You might want to check into that with your lender of choice just so you know where you stand.
04-22-2021, 08:11 PM | #1159 | |
11505
Rep 3,265
Buug95924057.00 |
04-22-2021, 08:17 PM | #1160 | |
24057
Rep 892
04-22-2021, 08:29 PM | #1161 | |
11505
Rep 3,265
Our lender is just wrapping up a refi for us on our primary mortgage + the HELOC we used to help buy the land. They will roll that all up into a new mortgage at a low rate, then when the time is right do the construction loan and the mortgage on the new house. By keeping it all in-house they make more money and we save as they are able to extend better rates and lower closing costs as they have more of our business. |
Buug95924057.00 |
04-22-2021, 08:40 PM | #1162 | |
24057
Rep 892
DETRoadster11505.00 hooligan_G016541.00 |
04-22-2021, 09:12 PM | #1163 |
7699
Rep 1,264
lol3
7
Buug95924057.00 IllSic_Design2125.00 vreihen1621707.50 DETRoadster11505.00 ramman434716.00 Kilabyte3986.00 |
04-22-2021, 10:11 PM | #1165 |
1256
Rep 1,602
Not uncommon in these parts. A dry well or french drain is usually added in addition so that water isn't trapped in the pipe. The drainage hole in the elbow of the pop-up drain is crap and easily clogged. It's easily replaced w/ a plumber's T. 4" diameter drain vs maybe a 1" x 0.125" slit.
- Jeff
bosstones' flickr |
06-01-2021, 11:36 AM | #1166 |
4781
Rep 1,189
The house is starting to get back to normal after the tornado. We got new gutters installed. Went with black, its a little different but it will work with the new siding color.
Untitled by Nick Wood, on Flickr Untitled by Nick Wood, on Flickr We also finally got to take the damn plywood down. Untitled by Nick Wood, on Flickr by Nick Wood, on Flickr Since the house is already a giant mess, we decided to have the front door moved from the living room to what was a dining room(we used it as a sitting room.) Untitled by Nick Wood, on Flickr Cleaned out the flower beds, put my flag back up, and tightened up the front porch a bit. Its starting to look a lot better. Untitled by Nick Wood, on Flickr Since we moved the door, the sitting room will now be an entry room. We decided to move everything we had in there to our small guest room. No one is going to come stay with us since we have 8 month old twins, so an office is a better use of the room. Untitled by Nick Wood, on Flickr Untitled by Nick Wood, on Flickr Not everyone's style I know, but my wife and I love it. It will be nice to have a clean kid free room to get some work done in, or just have a drink. The other benefit of this room, is that I can shut the door and keep the kiddos out of my bar when they start moving on their own. Untitled by Nick Wood, on Flickr |
RickFLM411916.00 vreihen1621707.50 IllSic_Design2125.00 bosstones1255.50 hooligan_G016541.00 nyalpine907562.50 |
