04-17-2024, 09:48 PM | #111 |
![]() ![]() 1759
Rep 2,162
Many other well established auto reviewers have the same complaints of the X3M. Savagegeese being the standout review in my mind.
2016 F80 | MG/SO | DCT | Adaptive M Suspension | 19" Black 437M Wheels | CF Roof | CF Trim
04-18-2024, 09:56 AM | #112 |
![]() ![]() 11204
Rep 9,180
has the x3 m50 power been confirmed? it's guaranteed this will be a heavier vehicle... so how much power will it be given to make it up?
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
04-18-2024, 11:24 AM | #114 |
![]() ![]() 242
Rep 381
As someone who has leased 2 M40i's in a row, the M50i sounds very promising. The M40i is an excellent vehicle and a great daily driver, much better than the X3M on that front. That said my lease is up this week and the M50 wasn't available, so I went with a '24 Macan S, looking forward to comparing it to the M40i. No way i'd get into a '24 M40i now knowing the M50 is just around the corner. Looking forward to the reveal.
'24 Macan S
Prior: '21 X3 M40i Dark Graphite/Black '18 X3 M40i Carbon Black/Cognac '15 X5 xDrive 30i M Sport Space Gray/Mocha |
04-18-2024, 01:30 PM | #115 |
![]() 527
Rep 299
It has not been confirmed. It did feel a bit more powerful, but not by much. There are new components in the engine though, they just wouldn't share yet the details.
04-18-2024, 01:32 PM | #116 |
![]() 527
Rep 299
Equilibrandt627.50 internalaudit168.00 |
04-18-2024, 02:06 PM | #117 |
![]() ![]() 1759
Rep 2,162
ynguldyn 's post on this thread indicates there will be an X3M.
https://www.bimmerpost.com/forums/sh...php?p=30977923 It also contradicts the statement made in the video where it was indicated idrive will be version 9. ynguldyn states idrive 8.
04-18-2024, 02:10 PM | #118 | |
![]() 527
Rep 299
It is definitely OS9. But we shouldn't get stuck on 8.5 vs 9. From a UI/UX perspective, they are nearly identical. It's the base code that's different and it's the one for the future. |
Xtabi1758.50 internalaudit168.00 |
04-18-2024, 02:32 PM | #119 |
![]() ![]() 122
Rep 228
I have an ID7 and an ID8 in a 2023 and 2024 respectively. Making the transition from ID 7 to 8 took probably a week. I think ID8 is slightly better from a usability point of view and it has a few more features that I like. The larger ID 8 display is also a plus as is the stubby shifter that does not get in the way. If you use the shifter instead of the paddles for "manual" transmission operation then the ID 7 setup is preferable.
04-18-2024, 02:40 PM | #120 | |
![]() ![]() 1759
Rep 2,162
I'm putting my trust in you stranger!
04-18-2024, 05:43 PM | #121 |
![]() 35
Rep 43
04-19-2024, 01:19 AM | #123 | |
![]() ![]() 652
Rep 1,842
I really don't understand what they were thinking when they designed the new interior. The >>>>>>>>>x5 lights on passanger dash? Curved screen that you have to try and stretch all the way to right edge to press on something, fine they have the dial at least but they really could have kept presets or just keep hvac and heated seat etc buttons. However one thing that I can't understand why would they move the distance control into a burned menu settings? Is this true that they don't let you set distance of adaptive cruise control by steering wheel anymore? When Audi went with touch controls, they actually did it right. Sure the black area around the display is a bit annoying but it looks classy, understated and very usable 3 displays. They are all for specific purpose.. What's next, window buttons are going to be little displays, imagine they get rid of turn signal stalk and they go "just wave your hand in direction you want to signal"...
2024 X3 m40i
04-19-2024, 06:48 AM | #124 | |
![]() ![]() 1278
Rep 1,659
Drives: 2023 X3 xDrive30i
internalaudit168.00 hyde652.00 |
04-19-2024, 07:56 AM | #125 |
![]() ![]() 11204
Rep 9,180
They mentioned the tires for a bit... they said low rolling resistance but are they still runflat or do we actually have a solid designed suspension around normal tires?
Also - it looks like it's externally larger but if we are getting a larger car... I want to be sure it comes with larger interior dimensions... the current X5 fails at this vs an X3.
Xtabi1758.50 |
04-19-2024, 07:58 AM | #126 | |
![]() ![]() 11204
Rep 9,180
04-19-2024, 09:30 AM | #127 |
![]() ![]() 1374
Rep 363
04-19-2024, 11:57 AM | #128 | |
![]() 527
Rep 299
04-19-2024, 12:10 PM | #129 | |
![]() ![]() 11204
Rep 9,180
I already have a list (partially based on some faults with the current vehicle which I really love btw) The below mainly applies to the M50 1 - As above, is the vehicle suspension properly designed around non runflat tires or are we stuck with runflats? 2- Will there be both passive and active suspension options? 3- Will there be an option for a sport or performance exhaust? 4 - Will there be an option for different seats? I.e. M sport seats? 5 - Will we have a proper audio upgrade not the crappy HK? 6 - Will the vehicle have more power w the B58 variant? What HP? 7 - What is the US Curb weight of the vehicle? All of these would answer a lot of questions ![]()
04-19-2024, 01:20 PM | #130 | |
![]() 527
Rep 299
internalaudit168.00 ASAP11204.00 |
04-19-2024, 01:55 PM | #131 | |
DINAN SELLER
230
Rep 623
2024 X3M COMP, 2019 X3 M40i DINAN, 2015 335xi DINAN stage 4, 2014 BMW i8, 2010 M5 V10 DINAN S2
04-19-2024, 04:30 PM | #132 | |
![]() 168
Rep 230
1.What is this locking rear differential that your BMWBlog as well as other sites mentioned, and how is that different from the M Sport Differential (2T4)? 2.Which G45 trims (30, 30e, 50) can avail of the M Sport Differential (2T4)? I realized last night that some 330is with the dynamic package could have been equipped with the 2T4 so maybe the upcoming X3 30 may also have that option. I'm from Canada, so 3. Will the PHEV variant be available to order in Canada, on launch date or soon after? From the articles I read, for the US, it will be the 30 and M50 trims that can be configured at launch date but maybe Canada will be treated more kindly. Thanks so much. Last edited by internalaudit; 04-19-2024 at 04:44 PM.. |
hb526.50 |
