11-09-2014, 11:42 PM | #1 |
![]() ![]() 653
Rep 1,843
Pressure washer recommendation needed
I just want to keep the vehicle spot free after a drive through rain with all that road grime on the vehicle. I was wondering if anyone is using a pressure washer to sort of blow all that mess away, and if so do you use a soap attachment?
Just took delivery of my Jet Black X5 and any suggestions in keeping it spot free would be highly appreciated. I really don't mind taking 5-10 minutes to just soak it ever couple of days if needed. If you think pressure washer is not required, and I can just use my regular hose attachment, please shoot away. Instead of doing a wash once a week or once every 10 days, I rather do quick washes in-between.
2024 X3 m40i
11-10-2014, 11:05 AM | #2 |
![]() ![]() 9
Rep 222
Drives: '12 BMW M5 Alpine White
I find a gas pressure washer on with its gentle tip gives you the flow/pressure combo to get cleaning done. Check out this video on Youtube. It is called the Uber Foam Cannon. I have been using for 2 years and it is a time saver and keeps the swirl marks down by getting a 90% clean without touching the paint.
11-10-2014, 11:41 AM | #3 |
![]() 1745
Rep 6,695
Drives: F30 340i
pressure washer and foam cannon combo is great. if you use that once a week you probably won't even need hand wash. you cay spray the car down with the pressure washer, foam it down, let it dwell for a few minutes, and rinse off. you can also look into waterless washes. spray on, wipe off, and the car is clean. look into ultima waterless wash or pinnacle waterless wash. hope this helps
11-10-2014, 12:09 PM | #4 | ||
![]() ![]() 653
Rep 1,843
So I am adding Uber Foam Cannon to my cart. http://www.amazon.com/Professional-F.../dp/B004GNZYY4 What kind of shampoo do you recommend? I don't have too much room, but if you guys say this is worthless, I can try to make some room: http://www.amazon.com/AR-AR118-Elect.../dp/B003B6KQZE
2024 X3 m40i
11-10-2014, 01:18 PM | #5 |
![]() ![]() 9
Rep 222
The foam cannon requires a pressure washer. You just need to make sure that the pressure wash you want to use has the standard metal threads/quick connect for accessories like the foam cannon.
I use the Adam's All - Purpose cleaner. You can get in 1 gal jugs. Very concentrated and works really well. Has a pleasant smell while you are foaming. |
11-10-2014, 02:11 PM | #6 |
![]() ![]() 653
Rep 1,843
Without getting a pressure washer, can I use one of these: http://www.amazon.com/Gilmour-75QGFM...dp/B000XTH1GY?
It has quick detach for rinsing, since all I want to do is clean up the dirt and possibly do it frequently (most likely after each drive in bad rain, or just get rid of salt in the winter) I think it's better I just avoid power washer for the time being, or at least until I get a proper one. What do you think?
2024 X3 m40i
11-11-2014, 11:02 AM | #7 | |
![]() ![]() 9
Rep 222
11-11-2014, 11:52 AM | #8 |
![]() ![]() 653
Rep 1,843
I understand, I think I am going to have to go back to just normal washes, because based on what I have been reading no matter what I cannot get it clean enough "Touchless" which is what I was hoping to do in-between regular washes, especially since I still have to dry it afterwards and any remaining dirt/dust after foam/rinse process will just rub it on the paint while drying since non of these soaps are "self dry" I guess not.
2024 X3 m40i
11-11-2014, 04:04 PM | #9 | |
![]() ![]() 117
Rep 159
+1 I was thinking the same thing recently. |
02-08-2015, 11:58 AM | #10 |
![]() ![]() ![]() ![]() ![]() 297
Rep 625
hyde
Grim and film will always remain after a pressure wash UNLESS You have invested on a very good nano wax or BETTER yet a nano coating like GTechniq, Cquartz, 22ple, or soon to be phased out Opti-Coat Then you can blow all the dirt off easily |
