01-18-2016, 08:28 PM | #1 |
1129
Rep 2,564
We've always understood that reducing weight at the wheels improves performance but I don't recall ever seeing instrumented testing. C&D did that as part of their GT350 article. Interesting results. To be honest I never expected the improvements to be so pronounced. I'll try to attach a snapshot of the text assuming you'll find it interesting.
Hopefully it shows up. Enjoy. |
01-18-2016, 08:40 PM | #2 |
2043
Rep 8,339
Cool. Good info.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
01-18-2016, 09:24 PM | #3 |
795
Rep 762
Over 10 years ago I saw a company that was making CF wheels. Their top model was CF barrel w/ magnesium center. Picked 1 up and could not believe the weight. As I recall the 20x9.5 was around 15lbs. Unreal. So I then asked how much? $10k a set in 2005. My fear would be curb rash. CF really looses strength when scratched. Cool article, thanks for posting.
01-18-2016, 09:46 PM | #4 |
1129
Rep 2,564
More text attached.
I'm trying to understand the numbers. It says the carbon wheel and tire combo weighs in the 40's and the aluminum wheel and tire is in the 60's. I assume that is per tire/wheel. The M3 wheels are only 22-23 lbs and the tires are probably similar so that weight is just around the 45-46 lb area which would be similar to the GT350 R carbon wheel/tire combo. Doesn't seem like the same level of savings could be had on an M3. Edit: and check out those replacement costs! |
01-18-2016, 09:48 PM | #5 | |
1129
Rep 2,564
01-18-2016, 10:01 PM | #6 | |
4075
Rep 4,106
305s Front, 315s rear and still lighter? Go measure the weight of wide enough wheels and tires and you'll see the difference. |
01-18-2016, 10:46 PM | #8 | ||
1129
Rep 2,564
01-18-2016, 11:35 PM | #9 |
13854
Rep 3,458
These light wheels improve performance but at an incredibly high price. There may be cheaper ways to gain that performance difference.
Runflat tires are about 26 pounds each and conventional tires are about 22-23 pounds each. Not the kind of weight improvement carbon fiber wheels give, but a good way to reduce sprung weight and improve performance. I can't weight (incorrect word intended) to wear out my RFT and put proper tires on my car. If I were a true enthusiast I would have done it when the car was new. I'm just too much of a cheapskate. |
01-18-2016, 11:35 PM | #10 | |
1309
Rep 2,785
I remember an old EuropeanCar magazine Z4M build. They put on some lighter Forgline wheels and gained hp/tq on the dyno(don't remember the exact numers 10+)just from having less rotational mass. Last edited by DieGrüneHölle; 01-18-2016 at 11:51 PM.. |
01-19-2016, 01:28 AM | #11 |
115
Rep 1,158
As they have always said: lose 100lbs of weight or 10lbs of rotating mass, shed .1 sec off in the 1/4 mile.
Not a shocker to me with this test. Just goes to show that losing weight in the most looked over area's will make a very significant difference. |
01-19-2016, 07:56 AM | #12 | ||
1129
Rep 2,564
Either way, the numbers reinforce the impact on one key area of the vehicle. Maybe it was just me, but I always thought the improvement was nominal. Not the case. |
01-19-2016, 08:31 AM | #13 | |
34144
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
Lighter is always better in performance cars. (As long as it is safe.) |
01-19-2016, 08:36 AM | #14 | |
34144
Rep 11,637
One of the first things I did when I purchased my M6 was dump the run-flats. I went with Conti standard tires because they were so light, even in the widths that the M6 uses. My next step was to go with the PZero Corsa System. Even thought they were marginally heavier, about 2-3 lbs per tire, the compound more than offset this difference. Cheers-mk |
01-19-2016, 03:06 PM | #18 | |
1778
Rep 2,952
A comparison: An engine with a lighter flywheel revs quicker and spools down quicker, but at the cost of momentum and tractability (read: smoothness). Another comparison: engines with a longer stroke produce more torque (which is the converted rotational inertia of the crankshaft), but at the cost of the same two other factors: momentum and tractability. Both are exactly the same things. Ergo: Permutation A: lighten the hub (i.e., the wheel compared to the tire), and you retain more inertia while gaining rotational acceleration. This is why tires are so often ignored when it comes to lightening: the farther in you can eliminate mass, the less of an effect the reduced weight will have on inertia. Permutation B: lighten the rim (i.e., the tire compared to the wheel), and you gain some rotational acceleration but at a much greater cost to smoothness and inertia. The effect works on other wheels, too. Racing bicycle wheels have been made of carbon/fiberglass/etc. for many years with the same exact benefits as goals: decrease mass (particularly near the hubs), and increase the performance possibilities of the rider -- the engine. It's also been common knowledge among hybrid owners that the lightest possible wheel-tire combo can not only make a significant difference in acceleration and handling, but it can also save substantial fuel -- less rotational mass to have to turn to get the car moving means less fuel burned.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: 'Johnny Boy' '23 CR MINI JCW 2-door. Gone (but not forgotten): 'Allie' '18 NBM Porsche 718 Cayman; 'The Blackened' '15 MG 228i M Sport w/aFe filter/scoop, JL 600/6 w/Hertz drivers, P3Cars multigauge, other goodies>> |
01-19-2016, 03:19 PM | #19 |
IG @bmwF9xG80
3873
Rep 7,624
Drives: G80 M3, X4M, G07 X7m50
What about going from 20s down to 19s within the BMW OEM wheels? Still a factor right
X7M50i 650whp St1 E30
X4M 740whp 60-130 6.5 G80 M3 840whp 60-130 4.82s | 9.4@148mph IG: @bmwF9XG80 |
01-19-2016, 03:19 PM | #20 | |
34144
Rep 11,637
Emboldened: Think Lexus LFA...they have trouble maintaining piston velocity on discontinuous surfaces because of the ultralight flywheel. Cheers-mk |
01-19-2016, 03:27 PM | #21 |
1778
Rep 2,952
Exactly. It's also why racing motorcycles with inline fours can rev so rapidly and produce so much horsepower, yet be relatively easy to ride: a very short stroke (relative to the bore) doesn't produce a ton of torque until high in the rev range. That's why I'll always have more respect for motorcycle road racers who decide to ride a V-twin; it's a much more difficult engine to use smoothly.
