      05-30-2016, 08:12 PM   #1
JoyRin
25
66
Drives: 2015 EB M235i manual
Question for any techs, stutter during start up for a corolla
Hey guys, so i've been trying to diagnose a slight problem with my friend's car and was wondering if i could get some help. So its a 2008 toyota corolla. The car stutters a bit when starting up. It'll be like....crank, crank, crank, sputter, then fires right up. Once started, it runs/idles fine and doesnt sputter. Only during the start up process. It gets worse the longer it sits, but it also gets better the less it sits (ie running a few errands, it gets better each time its started as long as it doesnt sit too long). Now, so far we've not experienced any no starts. Just a slight stutter. I changed the spark plugs which were very corroded but problem still persists.
Thinking it might be the fuel draining out of the rail, i primed the fuel pump but problem still persists.
I assume if i prime the pump and problem still persists, then the pressure regulator should be fine since that acts as a check valve and we dont think the fuel is draining out. I may be wrong tho....
The only thing i can think of is to change the fuel filter and clean out the fuel system including injectors.
With the exception of running a fuel pressure test, any ideas? Thanks in advance!
      05-30-2016, 09:13 PM   #2
EJT86
EJT86's Avatar
2400
3,789
Drives: 2018 M2
2022 BMW M240i  [10.00]
Rod Bearings
      05-31-2016, 07:13 AM   #3
JoyRin
25
66
Originally Posted by EJT86 View Post
Rod Bearings
Yikes....can u explain?
      05-31-2016, 09:59 AM   #4
EJT86
EJT86's Avatar
2400
3,789
Drives: 2018 M2
I was joking since all us M3 guys are paranoid and pretty much every other post is asking whether a symptom is related to rod bearings
      05-31-2016, 10:01 AM   #5
MightyMouseTech
MightyMouseTech's Avatar
4351
6,196
Drives: 13 135i 6MT LeMans Blue MSport
Could be low fuel pressure. How many times did you cycle the pump before starting it?
Could also be a leaky injector. Let it sit overnight and then pull the plugs.
      05-31-2016, 11:45 AM   #6
JoyRin
25
66
I cycled the pump 3 times waiting 5 sec each time. Ill def let it sit overnight and check the plugs. I do want to mention that the corrosion on the replaced plugs was of the white deposit kind, basically looking like the corrosion you find on battery terminals. I do know thats a sign of running rich, which can be caused by leaking injectors i assume?
And...lol @ ejt86...scared me
Edit: pardon my ignorance, but since this isnt a direct injected car, would i still be able to smell fuel on the plugs after i let it sit over night?
      06-04-2016, 01:38 AM   #7
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3170
4,146
Drives: 340 6MT, 50e, others
Sounds like a problem with the VANOS system, typical on the 2008 Corolla's
