10-18-2017, 02:16 PM | #1 |
757
Rep 6,878
Drives: 2014 BMW 435i X-drive
Straight Exhaust vs. H-Pipe vs. X-Pipe!
saw this today
pretty interesting
10-18-2017, 02:51 PM | #2 |
I'll get back to you
7535
Rep 2,132
X pipe sounds better, do you have stock in Amsoil?
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
10-18-2017, 03:10 PM | #3 |
#buildnotbought
13788
Rep 5,481
Very interesting. What they're saying about H pipes easier to be installed isnt necessarily true for bmw's where a lot of the dual pipes run next to eachother (on a lot of i6 engines)
As for NA engine tuning on european cars I always have the rule of thumb that every extra HP is allowed to cost around $50-$75. So if you're building a new exhaust system, adding an x piece inbetween is allowed to cost about $150 (and that is usually possible, a generic x piece isnt very expensive)
10-18-2017, 04:07 PM | #4 |
757
Rep 6,878
I wish
I spend all my money on cars
10-18-2017, 04:27 PM | #5 | |
ECUTek Master Tuner
10425
Rep 1,771
Drives: F80 M3 YMB
The issue is that the best exhaust for a naturally aspirated car is vastly different than what is best for a turbo car.
In a turbo car, the absolute best exhaust is one with minimum restriction and turbulence, as in a X-pipe or many bends/changes in flow. Why companies make "high performance" exhausts for these cars and use X-pipes is ridiculous....
10-18-2017, 05:55 PM | #6 |
436
Rep 2,062
Then why does the S63TU come with an x-pipe yet the S63 doesn't? Either way, I'm adding an x-pipe and putting Vibrant resonators (same ones M6Beast uses on his custom M6 systems, it'll look like the last picture) in place of the stock muffler that has two sharp turns inside the muffler itself.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's Last edited by m5james; 10-18-2017 at 06:52 PM.. |
10-18-2017, 06:34 PM | #7 |
#buildnotbought
13788
Rep 5,481
^the theory on either x and h pipe is that it creates a scavenging effect where the air in the adjasent pipe is sucked out creating a slight underpressure.
This would help sucking the combusted air out of the other cylinder bank when the exhaust valves in that bank open. If this is still effective in a turbo engine I dont know. There a turbo wheel/wastegate blocking that underpressure. Its something that should be measured. Still even in a turbo car the exhaust air is still pulsated, so resonant adaptations can influence that. Maybe they added the x-pipe mainly for sound experience; that was another benefit concluded in the video
10-19-2017, 10:27 AM | #9 |
757
Rep 6,878
now the question remains
what happens if you add an X-pipe AND an h pipe
10-19-2017, 10:32 AM | #10 |
2124
Rep 3,025
Do we really think that BMW isn't hiring engineers smart enough to figure out the proper exhaust setup for each car and what they do for one model doesn't necessarily mean the same will improve the performance of another model?
10-19-2017, 10:38 AM | #11 | |
757
Rep 6,878
this is the same team that brought us LOL thread vol1, 2 and 3!!!
10-19-2017, 01:32 PM | #12 |
2124
Rep 3,025
So I watched the video and the conclusion is that I just lost 15 minutes of my life that I will never get back, only to learn that an H or X pipe may give me a 0.28% increase in HP, which is probably w/in some margin of error and not of any statically significant value. I also learned that an X pipe may sound cooler if the under carriage allows me to properly place it but would still be better off installing a cat back muffler if I want an improvement in sound
upstatedoc7534.50 |
10-19-2017, 07:37 PM | #13 |
*May contain nuts
195
Rep 286
If you're interested in the raw sound pre-muffler, here's a short clip I took to demonstrate.
Driving-wise, there's significant drone at 1280rpm, but this will change with lengthened exhaust section to tailpipe. |
10-19-2017, 07:51 PM | #14 |
436
Rep 2,062
The picture above on the left is a stock X*M exhaust and there's no crossover at all. Does yours have one then?
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
10-19-2017, 07:57 PM | #15 |
436
Rep 2,062
BMW also engineers exhausts to be quieter for the mom's that may drive a car...that doesn't mean it's best for performance. While the S63 and S63TU aren't the same internally, architecturally they are the same and I'd be a fool to not believe that if the M5 benefits from an X-pipe that I could benefit from it as well. If BMW engineering was the greatest end all be all of things, there wouldn't be a billion dollar aftermarket industry. BMW can't even engineer plastic intake and cooling parts that last longer than 50k, injectors that don't cause complete engine failures, etc etc...shall I keep going? BMW may engineer the shit outta their cars, but there's also bean counters saying that corners need to be cut to stay within budget, manufacturing timelines, etc.
protecon194.50 |
10-19-2017, 08:01 PM | #16 | |
436
Rep 2,062
10-19-2017, 09:35 PM | #17 | ||
2124
Rep 3,025
The point of the video was on the same engine there was a negligible benefit and slight sound improvement. The latter is option, the former was fact. Last edited by omasou; 10-26-2017 at 08:51 AM.. |
10-19-2017, 10:16 PM | #18 | |
*May contain nuts
195
Rep 286
Keep in mind, I said it was tiny - I'm talking no more than 20mm ID.
VMAX 0-1000M ▒ ▒ 230@22.619 > 232@22.489
10-20-2017, 09:32 PM | #19 |
436
Rep 2,062
Ahh, I see. I just wanna hear the turbos more, so those two turns within the muffler can't be helping. I read about allmotor2000 on the F10 boards and he created a table on what lengths are needed to make a Helmholtz resonator to stop the drone.
10-21-2017, 03:03 AM | #20 |
*May contain nuts
195
Rep 286
Yeah I found the original formula it was based on, and built a calculator in Excel so I can plug in the exact RPM.
10-23-2017, 11:18 PM | #21 |
436
Rep 2,062
Well feel free to email that to me at m5james@yahoo.com :-)
10-26-2017, 06:01 AM | #22 | |
*May contain nuts
195
Rep 286
m5james435.50 |
