      06-22-2018, 02:02 PM   #1
750iHelp
12
20
Drives: 2007 BMW 750i
Rats chewed through wires. Pics attached!
07 750i
Rats got under the hood and chewed through some wires. Anyone know what these wires are for? I have some dashboard lights that I’m not sure if they’re related or not. The wires are located on the right side of the car next to the washer fluid.
Any help would be greatly appreciated!
View post on imgur.com
      06-22-2018, 08:10 PM   #2
Chihuahua
Chihuahua's Avatar
4615
3,422
Drives: E30 329iS, E65 Alpina B7
Get some hot sauce, the hottest you can find from a store. Blend it down into a fine liquid. Slightly dilute it in water. Put the mixture in a spray bottle, finely mist your engine compartment once per month. Peppermint, mothballs, etc will not work. Hot sauce mixture is the only thing I have actually seen work. Honda has a tape that is laced with capsaisin that you could also wrap around sections of wiring harness.
I can't tell you what part of the wiring harness that is, but I can tell you that whatever rat did this WILL come back, and he's already invited all of his friends. I see this on a very regular basis where I work. Do you keep the car parked in a garage at night?
Good luck.
      06-22-2018, 09:39 PM   #3
DanG
DanG's Avatar
11655
7,220
Drives: 2018 M2 AW DCT
2018 BMW M2  [8.01]
I had this happen to my M235i. $1,200 later it was fixed. I have rat traps around my M2 just to be sure it doesn’t happen again.
      06-23-2018, 02:56 PM   #4
EnintyToo
22
39
Drives: E90 325
Not everyone knows this... your comprehensive insurance coverage will pay for the repair less your deductible.
Dackelone10880.00
      06-23-2018, 03:24 PM   #5
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
73511
27,165
Drives: ///M3-E92-DCT Silverstone II
Is your car parked in a barn ?
Because I can see hay in your engine bay ...
Man...You should clean your engine bay ASAP !
Rats don't like it clean....
"MAX VERSTAPPEN" IS THE 2021+2022+2023+2024 F1 WORLD CHAMPION - #UnLeashTheLion -
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
      06-23-2018, 05:59 PM   #6
750iHelp
12
20
No the car was parked in my garage for 3 weeks while I waited on parts to fix the parking brake issue I was having. These pics were taken as I had just removed the nest that I found. I will be sure to clean the engine bay ASAP.
Anyone have any idea what these wires are for?
      06-23-2018, 06:33 PM   #7
overcoil
3153
5,582
Drives: M235i 6spd
Is there a plug those wires connect to that you can disconnect to find what does not work?
Usually the loom that runs down the fender i would guess are lights or supplemental restraint system. Can you follow the wiring further to see where it goes ?
      06-23-2018, 06:49 PM   #8
750iHelp
12
20
I’ll go take a look now and see what I can find
      06-23-2018, 06:56 PM   #9
750iHelp
12
20
I really can’t tell where the wires connect. They seem to run down right Side of the car.
      06-23-2018, 06:56 PM   #10
inTgr8r
inTgr8r's Avatar
2464
11,670
Drives: M2 Comp
That wiring is not OE.
Impossible to tell what it's for.
Looks a bit of a mess TBH.
'21 M2C Hockenheim Silver
      06-23-2018, 07:00 PM   #11
750iHelp
12
20
Hey man,
Not sure what OE means. It definitely is a mess after the rats got after those wires. I’m doing my best to avoid taking the car to a BMW dealership.
      06-23-2018, 07:01 PM   #12
750iHelp
12
20
Not sure if this is related or not, but I am receiving a “parking brake fault” error message. I have an OBD reader and it says that my brake light switch is faulty and my front left wheel speed sensor is not working. Could these wires have anything to do with this?
      06-23-2018, 07:05 PM   #13
Chihuahua
Chihuahua's Avatar
4615
3,422
If this happened while your car was parked in the garage you have rats getting into your garage on a regular basis, probably every day while you sleep. They are nocturnal. You need to find out the points of entry and seal them up, or this will keep happening. Rats need only 1/2 inch opening to enter an area.
      06-23-2018, 07:05 PM   #14
750iHelp
12
20
Yeah I just discovered this 2 days ago. I will be purchasing stuff today to ensure this doesn’t happen again
      06-23-2018, 07:05 PM   #15
Chihuahua
Chihuahua's Avatar
4615
3,422
Hey man,
OE = original equipment, i.e. "factory".
      06-23-2018, 07:17 PM   #16
overcoil
3153
5,582
Drives: M235i 6spd
This is what I put on my wiring when a rodent got to it
https://www.summitracing.com/parts/h...QaAmxLEALw_wcB
Rodents don’t like to bite into the metallic.
      06-23-2018, 07:49 PM   #17
750iHelp
12
20
So I was able to push aside the air intake and I saw that the wires extend downwards behind the front headlight. At this point, the wires disappear and I can’t tell where they go from there.
I have a parking brake error and my orange parking error light is on even if my car isn’t. Can these wires be the cause of this?
The parking brake light doesn’t immediately disappear when the car is turned off. Instead, it’ll stay lit for a little while before it turns off. Then, it’ll randomly turn on and off throughout the day while the car is still off. I believe this is what is draining my battery.
      06-23-2018, 08:19 PM   #18
overcoil
3153
5,582
Drives: M235i 6spd
Wish I could help but I don’t know enough.
I’m wondering is your parking brake electronic and activated by the transmission shifting into park or is your parking brake mechanical ?
      06-24-2018, 03:02 AM   #19
750iHelp
12
20
It’s an electronic parking brake on an 07 BMW 750i
      06-24-2018, 09:42 AM   #20
Poiseuille
Poiseuille's Avatar
5456
3,749
Drives: 2016 M4 DCT Tanzanite/Amaro
  [0.00]
  [10.00]
while back I had a near miss with this: in a 540i I had, found the front half of a mouse on my water pump, other half was on the power steering reservoir. never saw any other evidence.
      06-24-2018, 11:20 AM   #21
EnintyToo
22
39
Drives: E90 325
Hey man,
You must have missed my post. What are you worried about? Your insurance comprehensive coverage covers rodent damage. It does not increase your rates to make a claim against the comprehensive part of your policy.
The dealer has the proper diagnostic equipment and will be able to find all the wiring fault codes and repair the damage.
      06-24-2018, 11:27 AM   #22
Chihuahua
Chihuahua's Avatar
4615
3,422
Actually, rodents LOVE metallic objects; they use them to sharpen their teeth.
This is a better option:
https://www.amazon.com/Honda-4019-23.../dp/B00AJTG3N0
