      12-06-2023, 06:19 AM   #1
Swampus
9
Drives: 218i
BimmerLink Or Bimmercode
Hi,
As per title which app is the better of the two? (IOS)
I understand I can code out the error that I am currently getting with a SOS malfunction (flat battery) common once the cold weather sets in I understand.
Also what's the best Bluetooth OBD2 adapter to pair up to it?
Or would it be better to just change the battery?
After some research I believe the part no is 84102447710.
I think the main stealers are asking around £60 for a gen battery but these can be purchased for £15+ off the usual sellers on the net.
2018 218i auto
Swamps
      12-06-2023, 07:13 AM   #2
lnlyssg
United Kingdom
159
369
Drives: BMW 320i
They are for different purposes: Bimmerlink is for viewing stats, errors and clearing codes and Biimercode is for coding: changing settings. For your purpose it sounds like you would need Bimmerlink. Both are from the same developer and there's a list of recommended adapters at https://bimmercode.app/adapters/
      12-06-2023, 09:26 AM   #3
chowser51
chowser51's Avatar
2114
2,871
Drives: F33 430 and F39 M35i
for battery, bimmerlink (and doing rear brakes to put the ebrake in service mode).
for coding, bimmercode.
buy both.
use both.
POBEP415.00
      12-06-2023, 06:35 PM   #4
Swampus
9
Drives: 218i
Thanks Inlyssg, I thought they were both the same but with an added extra for the one asking a few more £'s, but I stand corrected so thanks very much.
I haven't decided what to do as of yet eg change the battery or try to code it out so a little more research to do
Swamps
      12-06-2023, 06:36 PM   #5
Swampus
9
Drives: 218i
buy both.
use both.
Thanks Chowser, as per previous post I haven't decided what to do as of yet eg change the battery or try to code it out so a little more research to do
Swamps
      12-08-2023, 03:14 PM   #6
Qsilver7
Qsilver7's Avatar
5106
8,313
Drives: F06 650ix GC / F15 X5 50i
You don't "code out" a battery. You do "code" it if you change the size or type. But if you simply replace it (a new battery) with the same size & type...then there's no need to code any changes because you didn't change anything that requires a new code. You simply register the new battery to start a new baseline (which is done with Bimmerlink).
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      12-08-2023, 09:57 PM   #7
ctcarbonari
ctcarbonari's Avatar
483
361
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
+1 to what everyone else has said so far!
BimmerLink will let you easily check the state of charge of your battery. So, if you fully charge your battery (with a charger), then you'll be able to monitor it w/ your driving habits.
If you're getting an "increased discharge while stopped" error due to a parasitic drain, then it is likely that there will be a code stored telling you which circuit is involved (i.e. comfort access handles come to mind) - and BimmerLink will be able to retrieve stored BMW codes for you.
I use the OBDLinkCX bluetooth reader. There are many others out there that work just fine. I like the OBDLinkCX because it has a low power mode (i.e. "sleep" so doesn't trip alarm) and it is very small & compact so I can leave it plugged in 24/7 and open up my BimmerLink Dashboard to check fluid temps, pressures, etc all very quickly.
CSBM52875.50
