05-31-2006, 04:34 PM | #1 |
![]() ![]() ![]() ![]() ![]() 72
Rep 840
Time Elapse video
Does anyone know if this is a setting on the digital camcorder or a post production thing that you can do a time elapse video shoot?
I want to set it up in the workshop while i'm modding and have it record a shot or so every 1-5mins span. so when it's played back at 30 frame/sec it'll be sped up. Any suggestion? |
05-31-2006, 04:40 PM | #2 |
![]() ![]() ![]() 785
Rep 7,308
Drives: see above.
I think this is normally done by using a camera rather than a video camera. Just a sequence of shots governed by the camera's system. My canon does it but never used it yet... Worth a look on your camera?
05-31-2006, 04:46 PM | #4 |
One of my two dachshunds:
![]() 56
Rep 663
This feature is actually more common on camcorders. Cameras have too high of a resolution for an effective video to be made out of them. The OP is talking about make a 30 fps video, not a slideshow as per pictures. Of course, you can still make your camera take pictures and then use an 3rd party app to compile low resolution video out of the pictures but that would be a pain in the ass, wouldn't it?
I'd check your user manual to see if you have such feature on your camcorder - it may only be available for the higher-end models.
I'm sorry about my outlandish behavior - there's too much blood in my alcohol system.
05-31-2006, 04:48 PM | #5 | |
Rep 7,308
Drives: see above.
05-31-2006, 04:50 PM | #7 | |
![]() 56
Rep 663
05-31-2006, 04:51 PM | #8 |
Rep 7,308
Drives: see above.
If you have windows - it has movie maker - select all the pics you take and drop 'em into movie maker - voila.
05-31-2006, 04:53 PM | #9 |
Rep 7,308
Drives: see above.
You can also output the movie in many different formats, incl. web streaming etc etc.
05-31-2006, 04:55 PM | #10 |
![]() 11
Rep 136
1. Get the biggest memory card you can.
2. Set the camera to snap a picture every 30-60 seconds. 3. Empty the memory card to your pc within one of those 30-60 second intervals, 4. Rinse and repeat # 3 for as long as you like. 5. Put the pictures together into a video using virtual dub or other movie making programs. |
05-31-2006, 05:03 PM | #11 |
![]() 56
Rep 663
xeta - but then you face the obstacle of having to remove (and reinsert) the memory card without moving the camera's original objective.
05-31-2006, 05:26 PM | #12 |
![]() 11
Rep 136
A 4megapixel camera with a 4gb card can take roughly 3,000 pictures. Thats about 50 hours @ 1 picture per minute.
Do you need to go over 2 days? |
05-31-2006, 05:47 PM | #13 |
Rep 840
i doubt i'll need to go beyond 2 days...if anything 8 hrs max i'm not doing monster garage. Hmm so the consensus seems to be camera set on timer
05-31-2006, 05:58 PM | #14 | |
![]() 56
Rep 663
With 3,000 pictures and assuming you want a smooth video of 24 fps (it could be smoother at 30 fps) that's only two minutes of video. Maybe instead of a picture per minute you can do a picture every 30 seconds so over a period of 8 hours that's just 960 pictures. The video will look smoother too if frames are only 30 seconds apart.
05-31-2006, 06:25 PM | #15 |
![]() 11
Rep 136
Exactly as squawks says.
Estimate how long you are going to work for, then set the picture ratio (1 pic every X seconds) to have a more complete video. |
05-31-2006, 06:39 PM | #16 | |
Rep 840
