      08-21-2024, 05:11 AM   #1
Sid2807
Drives: BMW X1 2019
Exclamation Bmw x1 engine stalled in water
hey, I’m Siddhant from India my X1 had stalled in water and it has happened before but that time engine flushing and changing oil solved it but this the service centre said there’s less compression in engine and the engine is starting but there was water coming out from exhausts and white smoke which was probably vaporised water tho they say it needs engine replacement is it really not fixable? As last time my car was in a lot more water and I even tried to start the car 3 times, this time I didn’t start it and turned off the engine so it doesn’t do further damage, so can it really cos this much damage to my car or are they just trying to rip my pockets
Would really be helpful to know your thoughts
      08-21-2024, 09:24 AM   #2
RockCrusher
2066
1,913
Drives: BMW 2024 M8 Competition Coupe
What if any damage the engine suffered can't be known at a distance. Someone has to get his hands dirty.
One way to approach this would be to drain the oil and change it along with the filter. Ensure the air filter is not water logged and there is no water anywhere in the intake system.
Remove the plugs and crank the engine.
Then perform a cylinder compression check. If compression is down in any or some cylinders the engine is (probably) toast. Probably. Depending upon the damage the engine might be repairable but you would be facing a complete engine tear down and relying upon the mechanic to be able to correctly identify the damage, and if repairable correctly perform the necessary repairs.
If the compression tests ok then new plugs and run the engine.
But whatever you possibly do one thing you must do is avoid water crossings.
DrVenture1619.00
      08-21-2024, 09:50 AM   #3
DrVenture
DrVenture's Avatar
1619
479
Drives: M550i 2022
2022 BMW  [0.00]
The above info is perfect. I would add that if you sucked in enough water through the intake to stop the motor, it may not matter that you did not try to start it again. Water doesn't compress, it can do a lot of damage to running engine: pistons, rods, etc. A turbo may push even more water in.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Premium Pkg|Luxury Seating|M668 w/ DSW06+
      08-21-2024, 12:41 PM   #4
Sid2807
Drives: BMW X1 2019
Thank you so much, btw is there any chance that only the gasket had blown which is causing less compression and they gave me the repair costs of 10lac Indian rupees or $11000
      08-21-2024, 12:56 PM   #5
starlights
350
739
Drives: G05 50i
Doubtful if anyone here can answer that question - take it to a different shop for second opinion. How did the water get in - is that something covered by your insurance?
DrVenture1619.00
      08-21-2024, 01:21 PM   #6
Sid2807
Drives: BMW X1 2019
The water got In as I was driving in heavy rain and there was water filled on road the water level was below front license plate - they say they dont cover mechanical and electrical wear and tear parts so I’m shocked what does it even cover then
      08-21-2024, 01:34 PM   #7
DanG
DanG's Avatar
11662
7,223
Drives: 2018 M2 AW DCT
2018 BMW M2  [8.01]
You need to read this thread: https://f87.bimmerpost.com/forums/sh....php?t=2109349
BMWCCA member Puget Sound Chapter
      08-21-2024, 02:37 PM   #8
starlights
350
739
Drives: G05 50i
Understood. I would certainly not classify this as wear and tear - it is related to the occurrence of a specific weather event (rain) and poor maintenance of roads (water logging). by local authorities. However, that said, only you can read through the fine print of your insurance policy to determine if this should be covered. If weather events are covered then it will be up to you to push back with your insurance agency.
Partly, it's also on BMW that their cars cannot handle driving through urban water logging. Lastly, now you know - you own a BMW therefore you should not be driving through water . Get a Jeep for that.
      08-21-2024, 02:45 PM   #9
DrVenture
DrVenture's Avatar
1619
479
Drives: M550i 2022
2022 BMW  [0.00]
Reading that linked thread, it comes to mind to know where your air intake is located on any given model. I just looked at my M550 and it appears to be about centered in the grill openings FWIW.
My concern would be hitting an isolated deep puddle without knowing it was there. That has happened to me a few times when commuting years ago, but in an SUV.
      08-21-2024, 03:30 PM   #10
starlights
350
739
Drives: G05 50i
Me too
Also wondering how would Hybrids fare especially if the battery has a chance to be exposed to water...
      08-22-2024, 04:20 AM   #11
Sid2807
Drives: BMW X1 2019
Thank you so much guys insurance agreed for the claim never driving in water again 😭
DrVenture1619.00
      08-22-2024, 08:40 AM   #12
starlights
350
739
Drives: G05 50i
Awesome that this worked out well for you! You may want to keep a Mahindra in your garage for the rainy days . Good luck with repairs.
      08-22-2024, 09:32 AM   #13
geko29
1758
1,550
Drives: 2023 M3 6MT
Me too
Hybrid batteries are typically VERY well sealed.
      08-22-2024, 09:41 AM   #14
zx10guy
5647
3,271
Drives: 2013 135i
For typical splashing and such, yes. Being submerged in water....not so much.
Originally Posted by Lups View Post
We might not be in an agreement on Trump, but I'll be the first penis chaser here to say I'll rather take it up in the ass than to argue with you on this.
