11-18-2024, 09:06 AM | #1 |
Rep 3
Customization of Home Screen Widgets
When I 'tap' or 'long press' on my widget to rearrange the widget order nothing happens. The widget will open, but the adjustment option to rearrange the widget order does not occur.
The Owner's Manual states the following: The widgets can be adjusted in the main menu. The adjustments can only be performed when the vehicle is stationary. If necessary,tap the icon. Press and hold the widget. The following adjustments can be made: Tap the add icon. A new widget can be added below the selected widget. Tap the delete icon. The widget is deleted. Tap the sort icon. The widget can be moved to the desired position. The software version on my 2025 X3 is: 7/2024.64 Any similar results or clarification to be able to preform this customization ? |
11-18-2024, 09:47 AM | #2 | |
155
Rep 56
11-18-2024, 12:35 PM | #3 |
BMW Owner
132
Rep 439
Drives: 2024 BMW X1 28i
By widgets, are you saying that your having a problem adding to the “SHORTCUTS” that provides quick access to important functions? Or that once you create them you can’t move them around to a different position?
I have the ID9 in my x1 & the SHORTCUTS can be moved by pressing & holding then dragging it to where you want it. SHORTCUTS are assessable by pulling the white line at the top downwards. However, if your referring to the ability to move around the placements within the center screen, I know the ID9 in the X1 can’t be done, so maybe it will not in the X3 either. Last edited by markronnie; 11-18-2024 at 12:37 PM.. |
