      11-28-2024, 12:08 PM   #1
markronnie
BMW Owner
markronnie's Avatar
142
464
Drives: 2024 BMW X1 28i
2024 BMW X1 28i  [9.00]
Does new gen X3 have data ports?
I learned that BMW removed the 2 data ports from the 2025 x1 & 2’s. They had them in the 2023 & 2024 models. Now vehicle is available with just 2 usb-c charging ports in front & 2 in the rear. There is no way to play music from a flash drive or transfer data to ID9.
Did they do the same in the 2025 3rd gen X3? Do they have data ports up front & or in the rear seat area?
      11-28-2024, 12:23 PM   #2
Ravenous666
Germany
713
911
Drives: 2025 BMW X3 M50 & 2024 BMW X3
From the pictures I've seen, there is the data symbol besides the USB-C ports in the center console.
On the new X1 and 2 series it only shows a power symbol on the 25 models.
So I'm quite sure we get USB-C ports with full data support in the X3 G45.
      11-28-2024, 12:44 PM   #3
avi66
avi66's Avatar
United Kingdom
4145
5,677
Drives: X3 M40d LCI
As mentioned above, the USB C ports near the centre console charging/storage area are apparently data enabled. The downside is USB C memory drives have a much larger profile than possible with USB A drives, and if you’re using the phone pad or storage area, it would be easy to knock.
I use a Samsung USB C (33.70 X 15.90 X 6.40mm), which was the lowest profile I could find at the time, but prefer to plug in the USB C data port under the armrest in my G01.
      11-28-2024, 01:01 PM   #4
Ravenous666
Germany
713
911
I use a 90° adapter for am USB-C Drive and this realy helps to avoid to knock it over.
https://www.amazon.de/MOGOOD-USB-Ext.../dp/B0C457XVDR
Next step will be to dismantle the memory stick ans cut off the USB-A portion that takes most of the size on USB-C sticks.
      11-28-2024, 01:57 PM   #5
avi66
avi66's Avatar
United Kingdom
4145
5,677
Drives: X3 M40d LCI
Not sure I follow, what USB A portion of a USB C drive ?
      11-28-2024, 03:40 PM   #6
Ravenous666
Germany
713
911
Depends on the stick
