      12-15-2024, 10:29 PM   #1
MiniCookie
21
REP
25
Drives: G45 X3 M50
Ambient light reset issue.
The x3 M50 I acquired appears to have reset the ambient light to its default blue setting every time I start the vehicle (I am almost always in personal mode). Am I missing something or everyone is experiencing the same thing?
      12-15-2024, 10:33 PM   #2
Ravenous666
Germany
1,042
REP
1,241
Drives: 2025 BMW X3 M50 & 2024 BMW X3
The ambient light is bound to the drive mode.
Usually the car reverts to the default drive mode after you turn it off. There might be a setting in the iDrive where you can define the startup default drive mode.
      12-15-2024, 10:35 PM   #3
MiniCookie
21
REP
25
Drives: G45 X3 M50
Yes the default mode is personal, and every single time I changed it it seems not be able to memorize it. And at a new start it reset back to blue.
      12-16-2024, 03:26 AM   #4
MidnightLight
MidnightLight's Avatar
350
REP
364
Drives: 2025 X3 M50
2025 BMW X3 M50  [10.00]
My wife and I have different ambient color settings, and so far our X3 M50 has always correctly restored our respective ambient colors depending on who's driving. Just to be clear: you do have your BMW ID set up, right?
      12-16-2024, 09:36 AM   #5
MiniCookie
21
REP
25
Drives: G45 X3 M50
I did, that's exactly the weird one.
joemas0.00
      12-16-2024, 11:26 AM   #6
MiniCookie
21
REP
25
Drives: G45 X3 M50
Alright I turned off the BMW ID cloud syncing, seems like it is working now.
      12-16-2024, 04:49 PM   #7
wheine4147
34
REP
54
Drives: bmw X6
You can go into the I drive and set the default mode you want. I had the same issue and changed the default mode to the one I wanted.
      12-16-2024, 10:51 PM   #8
MiniCookie
21
REP
25
Drives: G45 X3 M50
All right, this might be an existing bug for iDrive9 (or a bug in my vehicle). On/off the cloud syncing won’t help. I also tried to reset the whole iDrive9 system and re-added my phone as the digital key. And the default mode I set up is “personal,” so the personal mode somehow just intends to change the ambient light color back to the default blue color every now and then very randomly. Also, if you have 2 profiles and switch back and forth, it works just fine for both. It only happens when I have my own profile on the vehicle. I give up for now, and I will just change the color every single time then.
      12-19-2024, 06:20 AM   #9
drex89
REP
13
Drives: 2025 X3
I have the exact same issue in my car also. I have tried everything, including even removing my BMW ID which includes resetting the car like it was new again. If the car has been sitting overnight it normally will revert back to blue and then I switch the color. However, starting it several times in the same day it will normally stay in the brownish color I like better with my brown interior. I'm hoping it gets fixed through and update but the latest update didn't fix it. Let me know if you ever figure out a fix please.
Gorbi1.50
      12-23-2024, 01:05 PM   #10
MiniCookie
21
REP
25
Drives: G45 X3 M50
It works fine now, and I don't know why, it seems like all I need to do is switch to guest first, and then switch to my own driver profile, then select the color, with the car in a place it has good cellular signals, it all started working fine.
drex896.00
woh21.00
      12-24-2024, 12:44 AM   #11
undauntednyc
29
REP
16
Drives: BMW X3 M50
I use the fob (haven't tried to set up a digital card yet on my phone) and had to make sure I linked the fob to my profile. That seemed to do the trick for me. Also helped me avoid choosing my profile every time which is tied to my "personal" mode. Still spending a few minutes every day with my car getting to know all the settings and discovering something new every time.
      02-02-2025, 11:58 AM   #12
Gorbi
REP
Drives: BMW X3 G45
Hi,
anybody has solved the issue?
I have exactly the same problem: it resets to default blue whenever I get into the car (yes, sometime it doesn't but only if not too much time passed). I have one profile (bmw id) configured and always in a "personal" mode.
Now, I have found veeeerry interested thing The problem happens only when I set the color to "ivory" (translating from Polish, don't know if it's the same name in other languages but it's the 1st color on the palette - pale brown/beige). Setting the color to any other one (i.e. green) is permanent - never resets to blue. I have tested it many times with 100% results.
Any ideas?
      02-02-2025, 02:35 PM   #13
drex89
REP
13
Drives: 2025 X3
I have the exact same problem. The next closest color is more of a yellow and it works fine with keeping that color. The ivory choice ends up switching to blue when I get back in the car. I like the ivory color better since it goes well with my brown veganza interior. It would be nice to resolve this relatively minor problem.
Gorbi1.50
      02-02-2025, 04:47 PM   #14
MiniCookie
21
REP
25
Drives: G45 X3 M50
Exactly, I was trying to use ivory white when I post this thread. Now I am using ocean blue, everything works fine.
      02-06-2025, 03:50 PM   #15
Gorbi
REP
Drives: BMW X3 G45
I have reprted the issue to BMW. Interesting if anybody responds. Have you done it too?
      02-06-2025, 04:13 PM   #16
MiniCookie
21
REP
25
Drives: G45 X3 M50
No, I just changed to another color and didn’t bother reporting to them.
Gorbi1.50
      02-06-2025, 09:30 PM   #17
drex89
REP
13
Drives: 2025 X3
I didn’t report it either but I probably should.
      02-07-2025, 03:30 AM   #18
tuchkata
15
REP
35
Drives: BMW G45
I would like to report it too, as this is the preferred colour for my wife Where did you report it?
      02-09-2025, 06:56 AM   #19
mramella
11
REP
26
Drives: 4Runner
I'm having the same issue. Refuses to stay on ivory. Always goes back to blue. Oh well, first world problems. LOL!
      02-22-2025, 06:48 AM   #20
Gorbi
REP
Drives: BMW X3 G45
I found an email address in the My BMW app.
