07-15-2008, 11:00 AM | #1 |
![]() ![]() 10
Rep 327
M3 GTR rollout video - 2009 ALMS GT Champion
Technical Specifications BMW M3 Race Version. http://jalopnik.com/354225/chicago-a...now-with-video Weight: 2,535 lbs./1150 kg Tank capacity: 29 gallons/110 Liters Chassis/body: Unitary construction steel body with welded safety cell made of extremely rigid precision steel tubing; safety fuel tank in CRP sandwich tray; pneumatic four-stamp jack system Aerodynamics: Front fenders, rear apron, hood, roof, trunk lid, rear wing, front wings, and flared rear wheel arches in CRP Transmission: Carbon fiber clutch with hydraulic central slave cylinder; 6-speed sequential racing transmission with straight-cut, unsynchronized gears; additional oil/air cooler; quick shift system with ignition cut-out controlled by shifting force; mechanical limited slip differential with additional oil/air cooler Front axle: Based on production version, with increased wheel caster angle, enlarged track width and enhanced wheel camber; five-way adjustable shock absorbers; tubular stabilizer bar Rear axle: Based on production version, with enlarged track width and enhanced wheel camber; five-way adjustable shock absorbers, tubular stabilizer bar Front brake system: Six-piston aluminum brake calipers, inner-vented grey-cast iron brake disks 15.0 in./380mm in diameter Rear brake system: Four-piston aluminum brake calipers, grey-cast iron brake disk, 13.1 in./332mm in diameter Steering: Rack and pinion steering with electro-hydraulic power Wheels: Aluminum wheels, 18 inches BMW P65 Engine. Type: Eight cylinder, V-configuration Capacity: 3999 cc Bore x stroke: 92 x 75.2 mm/3.62 x 2.96 in. Max. output: approx. 485 bhp Max. torque: approx. 368 lb-ft/500 Nm Cylinder block: Aluminum cylinder block construction with bed plate lower section Crankshaft: Steel crankshaft Pistons: Forged skirt pistons Conrods: High-performance steel Cylinder head: Aluminum DOHC (Double Over Head Camshaft); four valves per cylinder Valve train: Four overhead chain-driven camshafts, valve actuation via rocker arms Intake system: Eight throttle valves, made of CRP with load-charge optimized ram tubes Exhaust system: Headers, mufflers Fuel system: Single cylinder multi-point injection Lubrication: Dry sump lubrication Cooling: Water/air cooler and oil/water heat exchanger Electrics/Electronics. Engine management: BMW Motorsport ECU 408 with two high-performance micro-processors; Individual cylinder injection and ignition; BMW Motorsport Lambda Controller Pit speed limiter, Quick Shift function; Engine data memory system Energy management: Electric energy management and monitoring with BMW Motorsport POWER400 control unit, networking of all sensors and actuators through bus system Wiring harness: Weight optimized Ignition coil: Eight high-performance pencil coils with integrated ignition drivers Spark plugs: High-performance spark plugs Cockpit: Free programmable LCD Display with integrated shift indicators Steering wheel: Quick release multi-function steering wheel w/ integrated display unit
GQ. Look Sharp // Live Smart
07-15-2008, 11:39 AM | #2 |
![]() 13
Rep 119
:eyebulge::eyebulge::eyebulge::eyebulge::eyebulge: :eyebulge::eyebulge::eyebulge::eyebulge::eyebulge:
I think my eyes watered from the amazement. Wow... I'm really looking forward to seeing some races with this superior machine. It will be nice to put Audi back in its place as number 2. :headbang: |
08-12-2008, 01:33 AM | #3 |
Enthusiast
12
Rep 272
i saw it in person at this huge car show in Pittsburgh a few weeks ago, its sooo sick! outdoor car show but everyone was at the Bobby Rahal BMW booth
Titanium Silver, Coral Red, Aluminum
