      01-14-2025, 09:54 AM   #1
l33v0nix
l33v0nix's Avatar
Singapore
124
137
Drives: G20 330i M Sport
M emblem on m50 front grille
is there a reccess/indent where the M emblem sits? or its flat surface?
also wonder if there is any blackout emblem size that matches this?
      01-14-2025, 10:34 AM   #2
Zirnitra
83
52
Drives: BMW X5
Hi. I believe the side trim badge [on CAN/EU] is the exact size as the front. You can get them with the black stripe.
I am not 100% how it is attached to the grill as I know the radar part is in the front but having a quick "fishing line check" it seems pretty stuck on but have not tried forcefully because of the sensors around the area.
Need someone much braver than me lol
      01-14-2025, 10:43 AM   #3
l33v0nix
l33v0nix's Avatar
Singapore
124
137
thanks for the attempt. do you mind taking a close up at the edge of the emblem?
      01-14-2025, 11:26 AM   #4
Zirnitra
83
52
Drives: BMW X5
Size:  362.6 KBName:  IMG_2971.jpg
Best I can do. By the looks of it, the badge does not sit flat so it may be a solid piece that is attached to the part. I do know that is where the radar part is so BMW may have done that so if you stick a much larger badge then it could interfere but no idea. I am sure there are BMW SMEs in this forum maybe they can confirm.
Good luck
      01-14-2025, 11:56 AM   #5
Ravenous666
Germany
836
1,044
Drives: 2025 BMW X3 M50 & 2024 BMW X3
BMW made it quite easy for the imposters this time. direct stick on without any clip or baseplate like it was on the G01 LCI.
Curious how many M badges they sell
      01-14-2025, 06:32 PM   #6
l33v0nix
l33v0nix's Avatar
Singapore
124
137
Attachment 3643991Attachment 3643990
Good luck
thanks for this. very useful. the radar should be at the plate beside, the part name is specifically called radom cover
      01-21-2025, 08:37 PM   #7
l33v0nix
l33v0nix's Avatar
Singapore
124
137
Good luck
sorry to trouble you again
if you have a measuring tape. can you measure the width of the emblem please?
in cm/mm side please
or anyone else having the m50 (which i believe mostly are)
      01-23-2025, 04:02 PM   #8
Zirnitra
83
52
Drives: BMW X5
Hi.
This should be the size for the front emblem.
      01-23-2025, 06:39 PM   #9
l33v0nix
l33v0nix's Avatar
Singapore
124
137
oh they are the same 55mm size? thanks once again. somehow it looked smaller
