      01-26-2025, 03:22 PM   #1
worldswinner
11
81
Drives: Honda Civic
Are you guys follow this recommend tire pressure?
Mine is 30 with unstaggered 20inch tire
Looks like lil lower than recommended
Should I follow this?
      01-26-2025, 03:30 PM   #2
Ravenous666
Germany
836
1,044
Drives: 2025 BMW X3 M50 & 2024 BMW X3
Usually the recommendation is quite ok and it was always a good match.
      01-26-2025, 08:48 PM   #3
TurtleBoy
TurtleBoy's Avatar
17991
25,053
Drives: 2019 X5 40i,2021 M340i
You should match the door jamb label when filing the tires when cold (60F or so). After driving the pressures shown in iDrive are adjusted for the tire temperature so if you are filling them when warm use those values.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50
      01-26-2025, 11:54 PM   #4
Sportstick
Sportstick's Avatar
5523
6,682
Drives: '15 228i and '24 X3 sDrive30i
Keep in mind the door jamb label advises of the proper inflation at GVWR, which means the full passenger and cargo load for which the vehicle is certified. That weight is also on the label. For more typical daily driver usage, you may find reduced inflation from those values is more comfortable while providing the performance and safety you expect. I run 36 psi front and rear, as I am almost always alone, sometimes with my wife in a front seat position, and rarely any cargo of significant weight in the rear compartment. When you measure your inflation, the temperature, per se, is not the issue but the tires should be "cold" in the sense that they are not heated from usage, but are at the ambient temperature of your environment, such as first thing in the morning, unless you park in a climate controlled garage overnight that doesn't represent the outdoor conditions. Tire pressure will vary 1 psi for each 10 degree F change in the ambient temperature, so seasonal adjustments are also necessary in addition to routine maintenance.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCA&Tension Strut w/Powerflex Bushings/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerf Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus
      01-27-2025, 02:37 AM   #5
avi66
avi66's Avatar
United Kingdom
4329
5,913
Drives: X3 M40d LCI
Keep in mind that in some countries the tyre pressure label shows pressure for different vehicle loads, not just full weight.
      01-27-2025, 07:31 AM   #6
TurtleBoy
TurtleBoy's Avatar
17991
25,053
The pressures are also engineered so the vehicle handles correctly and that is why you see a difference between the front and rear. If you change from recommended make sure you keep the same relative difference between the two and don't run the same pressure in both.
      01-27-2025, 09:58 AM   #7
Sportstick
Sportstick's Avatar
5523
6,682
The differential at GVWR is related to tire safety under load to prevent tire overheating and possible blowout from sidewall flex. The rear pressure is higher under these conditions due to an otherwise fairly balanced vehicle weight distribution being altered with rear passengers and cargo disproportionally adding weight in the rear. It is not necessary to keep a pressure differential in an unladen vehicle for a daily driver. It won't do any harm either, but will provide a somewhat harsher/bumpier ride. If that does not bother OP, having the differential pressures will keep the vehicle ready for more passengers and cargo. Vehicle handling with 36/36, especially in Sport mode with the Dynamic Handling Package, is excellent.
      01-27-2025, 11:41 AM   #8
TurtleBoy
TurtleBoy's Avatar
17991
25,053
No, the difference is for handling and inducing understeer.
      01-27-2025, 12:15 PM   #9
Sportstick
Sportstick's Avatar
5523
6,682
Yes, that may also be true in addition to the safety factor for carrying loads but experienced in more extreme driving that doesn't routinely happen on the streets for most drivers. However, the purpose of the door jamb label is a regulatory-driven source of information to inform drivers about maximum load and the associated tire pressure to carry that load safely to minimize the blowout risk from an overheated, flexed tire. NHTSA does not regulate the finer points of vehicle dynamics. But, those who track their vehicles certainly want to be diligent about tire pressure to optimize handling. However, from experiencing the 30i with DHP, 36/36 psi does provide excellent handling in Sport mode and the vehicle has taken some decreasing radius entrance ramps at very "spirited" speeds very neutrally. When in Comfort, the rear does not exhibit unneeded harshness. OP may decide how to apply all this information to their use case.
EDIT: I was interested to see how the online community discusses this and I found both the point you made as well as the load-carrying as the primary concerns on different websites. To varying degrees and depending on how the vehicle is driven, either or both may apply.
      01-27-2025, 12:29 PM   #10
Ravenous666
Germany
836
1,044
Not only the label, but also the tpms menu has a setting where you're able to set load conditions for tire pressure recomendation.
avi664329.00
      01-27-2025, 01:15 PM   #11
TurtleBoy
TurtleBoy's Avatar
17991
25,053
I have been doing a little reading also while sitting here waiting for a car wash and am leaning towards my original understanding being incorrect, at least not the main reason, and max load weight being the main factor. I have not found anything definitive but it seems like the majority on forums believe it is due to handling however looking at some articles and requirements for the label as well as info from manufacturers where they provide multiple pressures it seems like it is weight.
Like you said, probably a combination of both.
