      02-24-2009, 05:40 PM   #1
Kiemyster
Bimmerpost Resident Marijuana Consultant
Kiemyster's Avatar
Trinidad_and_tobago
501
3,202
Drives: 320i, 325xi, 335Xi, 335i, M3
Computer Help Needed- Vista related
long story short: my norton crashed my laptop. Destroyed the Disk.sys file. I removed the hard drive, put it in an encasing, and im trying to access my user files. it wont allow me to access my folder. how to bypass this?
i really need someones help with this..... i cant afford to loose my data.
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!"
'06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi
      02-24-2009, 05:50 PM   #2
Kiemyster
Kiemyster's Avatar
Trinidad_and_tobago
501
3,202
Originally Posted by anmcguire View Post
If nobody else comes up with a better vista-centric solution then I'd boot a linux livecd of some sort, mount the drive as an NTFS filesystem, and copy the data off that way.
do you have a link to send me to give me a better idea of what that proceedure involves/how to do it?
      02-24-2009, 05:52 PM   #3
Kensta335
Kensta335's Avatar
167
3,637
Drives: 335i Coupe
Are you on an admin account?
      02-24-2009, 05:57 PM   #4
Kiemyster
Kiemyster's Avatar
Trinidad_and_tobago
501
3,202
yes.
      02-24-2009, 06:00 PM   #5
radix
you know he kills little girls like you
radix's Avatar
403
892
Drives: -
Download and burn an ISO of a linux livecd. Ubuntu would probably be the easiest.
http://www.ubuntu.com/getubuntu/download
Boot from the livecd. Then, as root on the console or in a terminal, do
Code:
#fdisk -l
to get the block device name for your ntfs partition (e.g. /dev/hda1).
Next mount the ntfs partition.
Code:
# mount -t ntfs -o ro /dev/hda1 /mnt
Copy data off of a drive to another drive that you mounted using a similar procedure (say /dev/hdb1), or use ftp to copy the data off. You can compress your files in a windows friendly format like so:
Code:
# mkdir test
# touch test/{a,b,c}
# zip test.zip test/*
  adding: test/a (stored 0%)
  adding: test/b (stored 0%)
  adding: test/c (stored 0%)
Forget the mkdir and touch commands, they're only there to illustrate a point.
I'd only use this as a last resort though. There is more than likely a much friendlier vista-centric solution. I've used this procedure for friends when all else fails though. If nothing else works, PM me.
      02-24-2009, 06:13 PM   #6
Kiemyster
Kiemyster's Avatar
Trinidad_and_tobago
501
3,202
well i just destroyed my western digital passport 320gb hdd case to remove the hard drive. i mounted vista x64 on it and i just loaded it up into my asus.... say a prayer for me!
      02-24-2009, 06:18 PM   #7
b335i
b335i's Avatar
22
386
Drives: 2008 e92 335i, 2012 f10 535i
Easy, should have just booted to safemode, turn off simple sharing.
Then change security permissions for that directory (for all administrators or your specific username, etc) and apply changes to all child directories.
      02-25-2009, 01:08 AM   #8
Kiemyster
Kiemyster's Avatar
Trinidad_and_tobago
501
3,202
come on dude, dont you think i tried everything? i tried booting up in safe mnode, then with networking, then with command prompt, then with low rez video, everything. the shit wouldnt start.
but anyways, my diabolical plan worked out just fine.... didnt have to loose anything. thanks for your concern and assistance anmcguire!
      02-25-2009, 09:10 AM   #9
MadDog
Careful, I Bite.....
MadDog's Avatar
162
504
Drives: 2006 325i
2006 325i  [7.50]
Your account may have administrator privileges, but you are not the "Administrator".
This is how you activate the Administrator account:
1. Logon to Vista using your usual account.
2. Launch the cmd prompt - Make sure you select, 'Run as administrator'
3. Net user administrator password
4. Net user administrator /active:yes
5. Switch User, or logoff
6. Logon as Administrator Password password
(Your password may be different!)
Once you have logged on as the Administrator, try accessing your files.
      02-25-2009, 07:46 PM   #10
mrvuml
mrvuml's Avatar
20
459
Drives: E90 335i w/ZSP
2008 335i Sedan  [0.00]
What does turning off simple sharing achieve in this scenario?
