07-05-2006, 02:27 AM | #1 |
Torque junky
118
Rep 1,688
Drives: Remapped e90 330d
Garage floor: best paint type & colour?
I will shortly be moving to a new house where there is a great double garage with a smooth concrete floor just begging to be painted. My question is what type of paint should I use (is rubber based paint too squeaky/expensive?) and what is the best colour in terms of looks and resistance to scuff marks? Light grey sounds kind of nice, but will it show the marks?
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
07-05-2006, 03:50 AM | #2 |
85
Rep 157
Is this OT? Anyway...
There are tons of links available to help you with this. Every one of them will tell you to meticulous preparation of the floor is essential, no matter what you use. I used Rust-O-Leum Garage Epoxy. It has peeled up in a couple of places but overall has held up well. I can and do mop it and it's good as new. There are other epoxy products out there you can check out. Google it. |
07-05-2006, 05:35 AM | #3 | |
Got Seoul?
118
Rep 2,862
Drives: 2012 535i MSport
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
07-05-2006, 06:02 AM | #4 |
Torque junky
118
Rep 1,688
Grey epoxy it is then, thanks Sorry if this should have been posted in the OT section...
07-05-2006, 06:49 AM | #5 |
429
Rep 12,276
I've been trying to decide what to do with my garage floor for a long time. I've even considered putting down a vinyl floor (black and white checkered). As previously mentioned, preparation of the floor is paramount - and the hardest part.
If you decide to do it, good luck and post photos afterward!
I think it is bad luck to be superstitious |
07-05-2006, 08:16 AM | #6 |
Rep 50
Epoxy all the way!! I used an industrial coating from Vexcon www.vexcon.com I have had no peeling or lifting at all in a year of heavy use. This stuff is made for warehouse type traffic, and is put on in two stages- a primer/sealer and a two part eopxy coating that comes in multiple colors. I used grey- darker colors will suck up the ambient light at make it hard to see to work on stuff...
Many have used the rust-oleum product with success. I tend to shy away from mass market products of this type and go for the stuff that the pros use. |
07-05-2006, 09:14 AM | #7 |
391
Rep 4,320
Drives: '07 Z4 M Coupe
I used the Rust-Oleum stuff on our garage when my parents first built our house, and it's just starting to flake and need replacing (it's been about 6 years).
I need to redo it one of these weekends... when I have the time; it's definetely an all day event. I was happy with the Rust-Oleum stuff, but it's so expensive. Home Depot's selling it for like $70 a case, and I need 5 or so cases to cover the floor. Mackskibum - did you put down the Vexcon stuff yourself? How difficult was the install, and which item did you use? Their website has so many choices it's a bit confusing.
07-05-2006, 10:15 AM | #8 |
Rep 50
Used the Powercoat VOC epoxy- French Grey, Powercoat primer coat before I put the topcoat down. This stuff was not cheap either- probably similar in price to the rust-oleum. You may have a problem getting another coating to sick to the existing epoxy- usually for a recoat they will shot blast the old epoxy off prior to refinish.
Here's a photo: |
07-05-2006, 10:26 AM | #9 |
119
Rep 372
Drives: F36 435i M Gran Coupe
I have grey epoxy in my garage floor, its pretty good, but is starting to peel in some areas.
07-05-2006, 12:31 PM | #12 |
Rep 50
Traction depends on the finish on the concrete. I have a power trowel finish since I was planning on coating the floor. A broom finish would be similar. I don't have issues with the floor being slippery. If you have a smooth finish that may be different. I do know if you have a smooth finish you have to "roughen" it to get the epoxy to stick.
07-05-2006, 02:27 PM | #13 |
Recovering BMW Addict
154
Rep 1,914
Drives: <OO (|||)(|||) OO>
I also have gray epoxy. Need to prep the floors properly to ensure proper long term adhesion. I also added some lava sand to give better traction when wet.
07-05-2006, 02:32 PM | #14 | |
Got Seoul?
118
Rep 2,862
[SIGPIC][/SIGPIC] |
