04-06-2009, 01:09 AM | #1 | |||
1243
Rep 12,446
2010 Ford Shelby GT500 Test - I can dig it
Quicker, Smarter, Nicer — Yet Still a Bad Boy By Chris Walton 04-05-2009 Quote:
It's something like trying to drive the 2010 Ford Shelby GT500 on a roller-coaster, only there are no steel tracks to keep you from slithering off the pavement and ending up in a flaming heap of 540-horsepower Mustang. You can't even see where you're going, really. Hard on it, the GT500's rear tires begin spinning just as you can see nothing but sky in the windshield. You're on top of the hump at the entrance to Infineon Raceway's Turn 6, and as your stomach and both right-side tires go weightless, you start a long, long dive to the left, sliding sideways all the way down the hill and around the 180-degree corner. The Shelby GT500 is so torqued up with the cornering force from the low-profile 19-inch tires and the drive from the supercharged V8 that you can practically hear the welds popping in the chassis. But something is different this time — palms are not slick with sweat, tires are not threatening to let go at the most inopportune moment and steering left in order to go right is a joy and not a reflex of self-preservation. The 2010 Ford Shelby GT500 gets 2 mpg more on the EPA highway cycle this year. The Ford engineers are really proud of this. But every time we make another lap and slide down Turn 6, we have our doubts that fuel economy is what this car is about. Serving Our Inner Adolescent We're behaving like adults as the Ford engineers tell us all about the 2010 Ford Shelby GT500, even as we hear a couple of the cars making shake-down runs on the quarter-mile strip at Infineon Raceway a few hundred feet away. And in many ways, the GT500 itself is trying to act more like an adult, casting aside the muscle-bound character of the 2007 Ford Shelby GT500. As the Ford people tell us, they started with the limited-production 2008 Ford Shelby GT500KR, the exclusive (1,700 examples built) and revenue-enhancing (MSRP $79,995) Mustang produced last year. And aside from a few fewer Shelby badges (the KR had many to spare), the GT500 is like the KR in almost every way, except it's built at the Mustang plant in Flat Rock, Michigan, rather than at the Shelby facility in Las Vegas. You can tell as soon as you open the new GT500's hood, complete with hot-air extractors. The supercharged and intercooled DOHC 5.4-liter V8 with its truck-style iron block is still in place, but now it carries a conical air filter in its own sealed cold-air box behind the left-side headlight, an innovation that increases airflow while resisting power-sapping heat soak. For the GT500, this new cold-air intake required the migration of the iconic Cobra badge on the grille from the left side to the right side. With premium fuel and more aggressive ignition timing plus a less restrictive exhaust, the result is 540 hp at 6,200 rpm, an 8 percent increase. Torque output goes up fractionally to 510 pound-feet at 4,500 rpm. Thankfully, the telltale supercharger whine has been significantly diminished with clever intake plumbing, while the idle burble and bad-boy tailpipe blat have been accentuated by the 4-inch exhaust system. Totally Awesome It's not a lot of extra power, but your inner adolescent can put it to good use because the final-drive ratio is 3.55:1, 7 percent shorter than the former 3.31:1 rear-end gears. This means a useful increase in twist at the new, 19-inch forged-aluminum rear wheels, and the result is a blast to 60 mph from a standstill in a blistering 4.3 seconds (4.0 seconds with 1 foot of rollout, like on a drag strip). In comparison, the 2007 Ford Shelby GT500 made the run in 4.6 seconds, while the 2010 Chevrolet Camaro SS did the deed in 5.0 seconds (4.7 seconds with rollout) and the 2009 Dodge Challenger R/T recorded 5.5 seconds (5.3 seconds with rollout). Quarter-mile performance is totally awesome as well, as the GT500 makes its best pass in 12.4 seconds at 114.7 mph. That's not only a useful margin over the '07 car with its 500-hp powertrain, which did the deed in 12.8 seconds at 112.6 mph, but it also makes the Chevrolet Camaro and Dodge Challenger look like weak-ass sissies. The Camaro turned the quarter in 13.0 seconds at 110.9 mph and the Challenger did 13.9 seconds at 103.2 mph. We might have gone even quicker and faster in the Shelby GT, except for the 14-mph headwind we faced at this track close to San Francisco Bay. While it's as easy as ever to haze the rear tires off the line, the new softer tire compound has improved the bite. If you value bracket-racing consistency over all-out performance, the AdvanceTrac stability control's new Sport mode will do its best to optimize (though somewhat limit) traction for you. You might even select the launch rpm electronically for varying surfaces. Adulthood Comes to the Shelby GT500 Though the GT500 has that big beat from under the hood that gets your attention, it has the tractable character of the KR, so it's easy to drive. You can feel it in the controls. Everything operates with an easier, friction-free feel, so you don't feel like you're riding some kind of beast that's trying to spit you off at the first opportunity. The steering shaft is stiffer to deliver crisper response, even though the steering ratio remains at 15.7:1. The effort level for the brakes is scaled to humans, not superheroes. The shift action of the short-throw Tremec six-speed manual is short and sharp, not stiff. Even the clutch is surprisingly easy to modulate thanks to the use of larger, more robust copper/fiberglass plates that engage more progressively. Compliance and balance are the secrets here, an approach more grown-up than the former Shelby's brawny, stiff-legged tuning. Where the previous GT500 and especially the KR would hop over a lane line if there were a twig at the apex of a corner, the 2010 GT500 acknowledges road irregularities, but those events don't linger and oscillate more than once. Bam, and it's done. It begins with a compliant suspension tuned to deliver lots more roll control, only it comes from nearly twice as much rebound damping than before rather than simply stiffer springs. More negative camber at the front wheels also helps the steering bite with more effect when you turn into a corner, especially since the revised Goodyear Eagle F1 Supercar tires carry a softer compound. Balance comes from a revised aerodynamic profile meant to improve high-speed handling and stability. A revised front splitter reduces front-end lift by 31 percent, while the rear wing is trimmed out to actually increase lift. Downforce can be tuned with the small Gurney flap. Driving in the Real World This Shelby GT makes you believe you're in an exclusive performance car, not just a Mustang with a decal package. The seat upholstery is real leather and the inserts are suede. The rim of the steering wheel is suede. The silver trim for the dash is real aluminum, and it has a zippy dimpled finish. Soft-touch plastic is used and the gauges are specific to the GT500. When you fire up the car, the Shelby Cobra logo appears on the navigation screen. With one hand on the suede rim of the steering wheel and the other on the shift lever's white cueball (manufactured by an actual billiard supply company) that has been inscribed with the racing stripes that are the visual theme of the GT500, you're looking forward to the drive. We drive along California highway 1 from Stinson Beach to Fort Ross, and then cut inland through the California wine country to Calistoga. The Shelby lets you know that it has a live rear axle, but it doesn't make you slow down for fear of upsetting the car — a real breakthrough. If only it weren't for the seat headrests giving your head a nudge every time the axle kicks. And this thing gets fuel economy. Although the final-drive ratio is far shorter than before, 5th and 6th gears are much taller. So the result is an EPA-rated 14 mpg city/22 mpg highway. Coming to a Showroom Soon We can't think of a more difficult place to drive a 540-hp pony car than Infineon Raceway, but once all the Ford people were gone and we were left on our own with the 2010 Ford Shelby GT500, we did lots of time on this 2.5-mile roller-coaster. And once we flicked off the stability control, the Shelby GT came alive. You could flick the Shelby into corners, and we came down Turn 6 with smoke coming from the rear tires. And the brakes offered good modulation and a crazy amount of capability. By the end of a day, you can't help but like this car. It's stonking fast (though it doesn't always feel that way), it slides very controllably (especially when you find that special place that's like Turn 6) and it actually looks special (and exclusive) for a change. We'd even order one ourselves (though the stripes would have to go). You can order one for yourself when it arrives in dealerships in the early summer. The price of the 2010 Ford Shelby GT begins at $48,125, and this includes the now-lower $1,000 gas-guzzler tax (thanks to the GT's 22-mpg highway rating) and $850 destination charge. Loaded with options as our test car was, the price can easily surpass 50 grand, though. But like the original Shelby GT500, there's a level of sophistication and even luxury sewn into the fabric of this undeniably rapid and capable muscle machine. Sure, it'll throw down consistent 12s in the quarter-mile and slide around corners with glorious plumes of tire smoke, but it'll also tell you what traffic conditions lie ahead, play DVDs and promote marital harmony with dual-zone climate control. Name another 540-hp coupe for $50,000 that can do all that. Source: http://www.edmunds.com/insideline/do...opanel..1.*#20
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
04-06-2009, 01:13 AM | #2 |
1243
Rep 12,446
I change my mind about the looks after seeing these pics. I thought it was too soft before, but now it looks muscle-bound and actually unique for once.
The performance is nothing to scoff at, be it acceleration, braking or handling. Would I rather have it than, say, a Camaro SS or a Challenger SRT8? Probably, but I'm waiting to see Chevy's high-powered answer (what would have been the Z28).
04-06-2009, 01:34 AM | #3 |
Anti-Fanboy
68
Rep 572
I've always been a Chevy man, but this could change my tastes. This is probably the most entertaining sports coupe you can buy for $50K. Yes, I'm well aware you can get a Corvette for the same price, but Corvette's are everywhere. This won't be. Exclusivity counts for something, right?
04-06-2009, 09:34 AM | #4 |
Rep 166
I've always loved the GT500 and the new one looks to be even better. If I were in the market for a car in this segment, my mind will tell me "Z06", but my heart will say "GT500" all the way. It has that x-factor coolness that the Z06 can't begin to touch.
2008 Porsche 911 S 6MT [GT Silver/Cocoa extended leather/sport chrono/loaded] 2007 Porsche Cayman S 6MT [Black/Black extended leather/typical options] Daily Driver |
04-06-2009, 09:46 AM | #5 |
19
Rep 358
Love it.
2007 E92 335i - Alpine White, Coral, 6 Speed MT, Premium, Sport, Painted Reflectors, GT thunder Angel Eyes, M-Tec Fogs, Cyba CF Kidney Grills, Black OEM Lower Mesh, OEM Aero-Lip, 19" Staggered Matte Black VMR CSL Reps, General Exclaims - 235 Front and 265 Rear, Black Window Trim, BMS Dual Filter Intake, Britalman Catback Exhaust, CF Mirrors, CF M3 trunk lip, 5% Tint, Lamin-X Tinted Tails, Split Second Turbo Tuner.
04-06-2009, 09:52 AM | #6 |
43
Rep 158
My dad currently has a gt500 and i love it! I always ask him to drive it , its one of those cars that you just want to drive for no reason. The supercharger sound is just intoxicating. Mind you his car has quite a bit of MODS. Ive actually seen the new gt500 and to be honest it looks a lot better in pictures then it does in real life. I honestly think it looks softer in every way. The interior doesn't look all that different in real life compared to the current model either.
04-06-2009, 10:21 AM | #7 |
Moderator
591
Rep 4,240
I'm trying very hard to like this. I mean its got 540hp for crying outloud. It should be faster down low though. The car is so inconsistent. Look at CarandD, MT, Insidline, etc. The other have it trapping pretty high at 118 but doing the quarter in high 12's. None of the others have been able to replicate Ford's 4.3sec to 60mph. They got around 12.6.
- 04 Honda S2000(gone)
04-06-2009, 11:38 AM | #8 |
43
Rep 158
To be honest when these cars are stock they feel like a REALLY slow 500 hp lol. I don't know how else to describe it... But with such subtle performance mods these cars really come alive.
04-06-2009, 05:15 PM | #10 |
Registered Sex Offender
599
Rep 4,757
6250 red line? Seems kinda low to me
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
04-06-2009, 05:34 PM | #11 |
98
Rep 698
Drives: Mini Cooper S Paceman
The front looks like crossed eyed, everything else is really good,... I'd never buy one but still respect it's capabilities,... definitely a FUN car to drive!
04-07-2009, 04:43 PM | #13 | |
Anti-Fanboy
68
Rep 572
Motor Trend's times (4.7s/12.7@118 mph) were done in less than ideal conditions. The editors concluded that a faster time is no doubt possible. However, Edmunds was able to verify Ford's claims: "It's not a lot of extra power, but your inner adolescent can put it to good use because the final-drive ratio is 3.55:1, 7 percent shorter than the former 3.31:1 rear-end gears. This means a useful increase in twist at the new, 19-inch forged-aluminum rear wheels, and the result is a blast to 60 mph from a standstill in a blistering 4.3 seconds (4.0 seconds with 1 foot of rollout, like on a drag strip). In comparison, the 2007 Ford Shelby GT500 made the run in 4.6 seconds, while the 2010 Chevrolet Camaro SS did the deed in 5.0 seconds (4.7 seconds with rollout) and the 2009 Dodge Challenger R/T recorded 5.5 seconds (5.3 seconds with rollout). The 2009 Dodge Challenger SRT8 does it in 5.1 seconds (4.8 seconds with rollout). Quarter-mile performance is totally awesome as well, as the GT500 makes its best pass in 12.4 seconds at 114.7 mph. That's not it; one of the photos near the bottom of the page has a caption that reads: "Using the standard timing system at Infineon Raceway, we cut one quarter-mile run in 12.2 seconds." Because of the front-bias in its weight distribution, I think traction will be a major issue, and you would need to be drag racing it in near perfect conditions to reproduce Ford's claims. However, if I had the money I wouldn't let this stop me in the least. |
04-08-2009, 07:28 PM | #14 |
D to the X to the B!
357
Rep 2,106
The updates look awesome..... Exterior wise,it's the first time I ever liked a GT500.
Anyway, those times are way better then the old GT500KR. I think this car has a learning curve for launching it properly like most 'High' hp RWD do. Once you get the hang of it, into high 11's. Anyway, I'm being optimistic but it does have the potential to do so. And Btw, according the article, this car handles pretty well too....this makes it even better
11 corvette C6
