08-03-2009, 04:45 PM | #1 |
![]() 34
Rep 1,025
NEED HELP:Nikon owners
hey guys!
I have the Nikon d5000 but i don't know how to use it yet.Just got it last week so...And yes,I only got the regular lens that came with it the 18-55 one. Does anyone out there know which are the best settings for it?like the P,A,S,M?what settings do you guys use for outdoor/indoor pics?i just want to take clear not blurry pics. tia, Ryan |
08-03-2009, 05:34 PM | #2 |
![]() ![]() 399
Rep 2,526
There is no "best setting" unless it pertains to a particular type of photography. Sports - I would just do P since that allows you to shoot quickly with some flexibility in your aperture and shutter speed settings. Portraits - A so you can vary the DoF. Landscapes - M for tricky lighting situations where the camera can't meter correctly.
If you're wanting to take clear, sharp, photos, look into getting an SB-600 flash. That thing solved all of my indoor shots problems. Used to use a D60 + 18-55mm VR + SB-600. That thing made such sharp photos. Could have been better had I been using a 50mm f/1.8. For outdoor, in the daylight, I would find it impossible to produce blurry photos unless you're shooting at a tiny aperture like f/22. I just keep my aperture around the f/2.8-f/8 range no matter the situation or environment. |
08-03-2009, 05:46 PM | #3 |
aka 1013MM
![]() 1362
Rep 9,545
I use A a lot because it sets the speed for me, I use M when I am in a setting which gives me more free time to adjust everything. S I will use only when I need know what speed I need to adjust to, rarely though.
08-03-2009, 06:45 PM | #5 |
aka 1013MM
![]() 1362
Rep 9,545
Aperture is easier to grasp than shutter speed for me
08-03-2009, 08:32 PM | #6 |
192
Rep 2,391
did it come with a manual?
08-04-2009, 01:32 PM | #8 | |
![]() ![]() 180
Rep 2,355
However, in in-door shoot, if I have my flash on, I shoot M and set it right to compensate my flash. It depends. I dont use S a lot, simply because A often solves the problem for me. At first I use M at all times, but I found that would make me "miss" many of the shots that I want.. thus I use A a lot more now. Oh, the pre-set settings are pretty useful too I found. I used the "sports" and "landscape" and they are pretty close to the setting I'd want if I were in M. (usually anyway). (PS. i use Canon, but they're the same)
2015 F80 Fully loaded (minus the CCB) YMB M3 / Individual Amaro Brown
BBS | KW | Vorsteiner | IND | Akrapovic | BMW CF Performance Interior | Brembo | Eibach 2008 E92 335i (sold) |
08-04-2009, 02:08 PM | #9 | ||||
![]() 34
Rep 1,025
thanks for all the info guys! ![]() |
08-04-2009, 03:42 PM | #11 |
![]() ![]() 77
Rep 2,937
The sticky above looks like your first port of call
http://www.e90post.com/forums/showthread.php?t=277439 |
08-04-2009, 04:39 PM | #12 | |
192
Rep 2,391
you really ought to read it. ;]
08-06-2009, 04:38 PM | #13 |
![]() 34
Rep 1,025
08-06-2009, 04:39 PM | #14 | |
![]() 34
Rep 1,025
08-12-2009, 01:35 PM | #15 |
Rep 21
You should first go through the user manual.
BMW E46 2008 BMW Parts Wheels
