10-28-2009, 05:38 PM | #1 |
![]() 326
Rep 3,635
Drives: R56 Cooper S
My first attempt at rig rolling shots.
...and it looks like I'm in need of a lot of help.
Here are the final products: ![]() ![]() Here is an original. I had to use WAY to much PS to make it look halfway decent. ![]() I only had a short pole so I couldn't get the whole car in the frame. I'll go to Home Depot to get a longer one. Some questions: 1. Is it possible to do this in bright daylight without a filter? I couldn't get any long exposure times even with f22 and ISO100. You must have to be driving ad 50mph+ to get any motion. 2. Is it better to push the car or drive it? I found the car to be sharper when pushed (the two I posted are being pushed at 1mph max), but the motion blur obviously wasn't as apparent. So if you guys have any tips, tricks or criticisms let me know. Thanks guys. |
10-28-2009, 05:46 PM | #2 |
Apex Everything!
![]() 1027
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
Definitely need a dark ND filter in the day time. I like to push the car for at least 10-15 seconds. No need to drive the car.
Be careful pushing the car too fast especially if the ground isn't completely smooth. My camera started bouncing a bit because I was pushing the car too fast and ended up putting a small dent in my roof. I'm sure the hood is a bit stronger though.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
10-28-2009, 08:14 PM | #3 |
![]() ![]() ![]() 723
Rep 5,382
what lens are you using?
10-29-2009, 01:06 AM | #4 |
aka 1013MM
![]() 1362
Rep 9,545
get a wider lens!!!!
10-29-2009, 07:11 PM | #6 |
Loading...
![]() 377
Rep 2,187
Drives: 91' E30 318is
Um on a side note, the second picture looks fucking awsome!
10-29-2009, 11:53 PM | #7 |
Rep 5,382
have you read this article?
http://www.rigshots.com.au/howto1.ht..._shutter_speed
10-30-2009, 11:15 AM | #8 | ||
![]() 326
Rep 3,635
http://www.diyphotography.net/take-c...alized-car-rig Quote:
11-01-2009, 12:03 PM | #9 |
![]() ![]() 157
Rep 346
Filters are the only way for daylight. Even at ISO50 @ f32, I have problems. A 10 stop ND filter would be awesome but need to be careful of vignetting on a UWA.
I would recommend pushing the car with the gearbox in neutral. Less vibration from the engine and only vibration should be from the road. This was the original motion shot ![]() Here it is finally edited ![]() I had to use a composite of the stationary shot and the motion shot to bring back sharpness. If I had pushed, would have required WAY less editing. |
11-02-2009, 01:28 PM | #11 |
![]() 326
Rep 3,635
OK, looks like I need a filter. Something like this would probably work:
https://www.adorama.com/HY58PF.html |
11-02-2009, 01:41 PM | #12 | |
![]() ![]() 157
Rep 346
11-02-2009, 02:06 PM | #13 |
![]() 326
Rep 3,635
11-02-2009, 02:11 PM | #14 |
![]() ![]() 157
Rep 346
Something along these lines.
https://www.adorama.com/BW62ND8XDP.html |
11-02-2009, 03:42 PM | #15 |
![]() 326
Rep 3,635
^^ Cool- I might just go with the adjustable polarizing one for the versatility for now. If I do, I'll definitely post the results/feedback here.
Thanks for everyone's help guys! |
