      06-03-2010, 08:05 PM   #1
Mark
Administrator
Mark's Avatar
7031
4,203
Drives: 1M
New Details on BMW's upcoming 3-Cylinder Powerplants
BMW Insider Scott26 has posted up some very very interesting and tantalizing news on BMW's future engine productions, which are of course very much in the vein of EfficientDynamics. The new engine in question is a 3-Cylinder engine that BMW has developed for use primarily within the next generation 1-Series (possibly 0-Series?), 3-Series and MINI cars and then would obviously filter its way into other cars in the BMW range in the typical fashion.
Whats most important here is the title. The new engine design will be based on a new 500cc per cylinder philosophy that could be used in a modular fashion in a fashion similar to how manufacturers can build many different sized cars based on a shared platform. So that means engines going anywhere from 3 cylinders to 8 cylinders could use the same design scaled up and down as BMW sees fit.
Because of the additional use of both turbo charging and direct injection, we should see some phenomenal engine output while retaining fuel economy relative to the given engine size.
Here is the original post in his words:
Three to Eight
500cc : A New Base in Engine Design
It is no secret that in terms of downsizing it's CO 2 levels BMW are moving to replace it's current range of engines with new Three,Four, Six and Eight Cylinders.
The new three cylinder will be part of a range of engines utilising a new common 500cc per cylinder base design which also uses Direct-Injection and Turbo charging. This engine will feature in many BMW models but will not be perceived as a Base engine or entry model.
The new 1er and 3er will receive it first but other BMW/MINI models will also inherit this engine.
Forget about the terms associated with Three-Cylinders such as weak or underpowered. This is a BMW engine and for a three cylinder it will offer excellent refinement with a sporting edge plus delivers an excellent CO2 output.
A lighter engine will also contribute to a weight reduction in the car also. The upcoming four cylinder Turbocharged engines in three range variants will also follow this procedure , The first TurboCharged four will be introduced in the new BMW 1er in 2011, and then follow into the BMW X3 which then follows the debut of the all new BMW 3er Sedan in late 2011.
The New range of Turbo charged engines will bring many new innovations for the first time in a new product launch and the 1er is that model.
The idea of using 500cc pe cylinder in future BMW engines which will rise from the 1.5 right up to a V8 will save resources in engine development costs and engine production.
      06-03-2010, 08:30 PM   #2
DBFIU
Crack Addict
DBFIU's Avatar
99
759
Drives: Fast
Freaking cool.
2009 - Titanium Silver - Steptronic - 135i - Nasty
      06-03-2010, 08:32 PM   #3
sb335is
92
736
Drives: fast
id like to see actual output and mileage comparisons. im always skeptical
      06-03-2010, 08:34 PM   #4
ArabianSensation
ArabianSensation's Avatar
38
475
Drives: M3
3er is getting to be quite a big car to be powered by such a small engine. Hopefully it will be a sufficient enough powerplant. If it is, great, but I won't be buying one
      06-03-2010, 09:24 PM   #5
Mike@F1 Autohaüs
Mike@F1 Autohaüs's Avatar
195
1,985
Drives: ❤
This will be great for daily commuting
      06-03-2010, 09:56 PM   #6
bavarian19
bavarian19's Avatar
547
18,849
Drives: Car
      06-03-2010, 10:03 PM   #7
Xyloft
Xyloft's Avatar
35
504
Drives: 2008 AW 128i
crosses fingers for a 1500 cc motorcycle engine based on this
      06-03-2010, 10:10 PM   #8
Oulixes
Oulixes's Avatar
22
1,938
Drives: 330xi, 335i
The race to make engines with as few cylinders as possible evokes the two-cylinder two-stroke engine used to power a German marvel called Trabant. Happily, the two-strokes of yore are currently as politically incorrect as diesels used to be.
      06-03-2010, 10:20 PM   #9
vladberca
vladberca's Avatar
Romania
778
5,567
Drives: '18 octavia 2.0 tdi dsg
I think it will have about 120hp and will be the base engine fit into 316i model, available in Europe.. For sure we'll not see it for other markets..
I'm curious for the final specs
      06-04-2010, 12:14 AM   #10
smack
smack's Avatar
Germany
34
1,569
Drives: BMW's/Flex Polishers
I would love to have this in a 1er hatch here in the U.S. Something very small with a little engine to get back and forth to work would be great.
      06-04-2010, 04:12 AM   #11
RussRamz
M Slut
RussRamz's Avatar
21
564
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
+1 Watching all the einser's run around here with the diesel badges makes me feel the same way. These cars easily turn in close to 60 mpg.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      06-04-2010, 05:25 AM   #12
BMW269
445
3,888
Drives: BMW
Scott said: "500cc from 3 to 8"
This means:
500cc x 3 = 1.500cc I3
500cc x 4 = 2.000cc I4
500cc x 6 = 3.000cc I6
Actually the V8 is:
550cc x 8 = 4.400cc V8
As Scott said "to 8", it means it will change:
500cc x 8 = 4.000cc V8
But as the V12 is also a 500cc:
500cc x 12 = 6.000cc V12
Why does not Scott say "500cc from 3 to 12" ?
I would then assume that the V12 is going to change and become
this:
450cc x 12 = 5.400cc V12
or even this:
400cc x 12 = 4.800cc V12
But as the new V8 is going to be a 4.0l (500cc x 8), I wounder if we shall see a new V10
500cc x 10 = 5.000cc V10
derived from this new V8, which could take place in the new BMW Z Spyder Stradale ?
      06-04-2010, 08:53 AM   #13
and 1
winter mode
and 1's Avatar
Italy
63
2,057
Drives: 08 135i, 88 M3
1988 BMW M3  [0.00]
2008 135i  [7.50]
Sweet idea....I was about to say "I can't believe no one thought of this sooner," but actually, bmw already has. Look at the e90 6 cyl engines. 3.0L / 6 cylindedrs = .5L per cyl. Or what about the old 540 v8? Wasn't that a 4.0L? 8/4=.5
Btw if none of this makes any sense, I was at an open bar party with my coworkers starting at 230pm yesterday.........
88 M3: BMWCCA J Sport
08 135: because streetcar
      06-04-2010, 09:02 AM   #14
NL-J
NL-J's Avatar
Netherlands
21
313
Drives: F82 M4
I thought BMW was about "Freude am Fahren"? How does a 3cyl engine fit into that?
*putting on flamesuit*
      06-04-2010, 09:18 AM   #15
BLITZ
BLITZ's Avatar
United Kingdom
32
228
Drives: E34 525i M-Technik
3 cyl does not belong in a BMW.
      06-04-2010, 09:34 AM   #16
NL-J
NL-J's Avatar
Netherlands
21
313
Drives: F82 M4
Thing is, all cars around here with a 3cyl engine are really small and ugly(that of course is a personal thing ) Daihatsu's, Smarts, Toyota's to name a few. Why would they put a 3cyl engine in a 1 or 3 Series? Fuel economy? I doubt that as I think it would be too small for such heavy cars? Besides that, look at the 320d Efficient Dynamics, that car is awesome when it comes to fuel efficiency but you can also drive it sporty as it has quite some power Why then putting a 3cyl in it?
      06-04-2010, 11:02 AM   #17
cotmfk
cotmfk's Avatar
2150
6,177
Drives: M3
Wow. 3 cyl.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
      06-04-2010, 11:02 AM   #18
marcel b
marcel b's Avatar
137
1,898
Drives: F31 340i
the 3cyl. will of course be charged and going up to around 170bhp/260Nm. Will drive better then all the current 4cylinders, I am sure.
Sound is something I'm wondering about...
      06-04-2010, 11:03 AM   #19
marcel b
marcel b's Avatar
137
1,898
Drives: F31 340i
This means:
Actually the V8 is:
this:
or even this:
I think there will be no 10 or 12 cylinder engines. With the V8 then can go to 600hp... maybe a 12cyl. as prestige / for some markets.
      06-04-2010, 11:28 AM   #20
Imola.ZHP
Imola.ZHP's Avatar
129
2,218
Drives: 2014 BMW i3 BEV EE
^ I agree with what he says...
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17-
- 2015 CPO i01 BEV Laurel Grey Tera World, '17-
- 2015 i01 REx Laurel Grey Tera World, '15-'17
- 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15
      06-04-2010, 12:25 PM   #21
magbarn
187
426
Drives: '17 540i Msport
QFT... No one has been able to design a smooth 3 banger yet. It's an inherently "rough" running design.
G30 540i Msport
G05 X5 xDrive40i Msport
Retired '03 330i, '10 335d
      06-04-2010, 01:16 PM   #22
Red Bread
4458
9,160
Drives: Smog machines
So are I4's, and BMW has a rather long history with those.
