      04-26-2011, 01:03 AM   #1
-=Hot|Ice=-
Been There, Done That.
-=Hot|Ice=-'s Avatar
702
4,728
Drives: 2013 BMW M3
MotorTrend:Why the Boss Mustang Failed Our Brake Test
Originally Posted by MotorTrend
Road test editor Scott Mortara headed down the quarter mile in the bright-yellow Boss 302 Mustang, steadying his speed for Motor Trend’s standard brake test, just as he’s done a thousand times before. Back in the day, before anti-lock brakes and stability control systems and decent tires, you never knew quite which direction the car might be facing when you finished a brake test. These days, though, it’s fairly simple: At about 70 mph, you grenade the brake pedal and hang on. The electronic nannies keep the cars nice and straight, and our sophisticated on-board data-logging equipment automatically captures the distance it takes to decelerate from 60 mph to a standstill.
So when Scott punched the Mustang’s brake pedal and it went straight to the floor, it got his attention. He quickly ran the six-speed manual back through the gears, slowing the car enough to make it through the gap in the wall at the end of the track.
Total brake failure during regular performance testing is a very rare occurrence. I’ve had plenty of cars get squishy pedals and smelly pads after hot laps around a road course. But in more than 25 years of testing, I’ve never known of such a complete—and potentially catastrophic—loss of braking.
Earlier, this particular Boss 302 had repeatedly lapped Laguna Seca and been driven enthusiastically along some of California’s more challenging back roads. Scott had then driven it directly back to Motor Trend HQ in El Segundo so we could get the photos, video, and test numbers we needed for last month’s print and iPad editions, as well as our website and YouTube channel. Had the Mustang’s brake pedal gone to the floor any time in the week before it did, the consequences could have been horrifying.
So what went wrong? Scott heard a metallic snap as he braked. A quick look in the Mustang’s footwell revealed the pin connecting the pedal to the master cylinder clevis rod end had sheared.
The Mustang’s brake pedal arm is normally located between the two sides of the clevis, and even if the clevis pin should fail, after a very short interval the back side of the pedal arm would act against the base of the clevis with enough force to actuate the master cylinder and apply the brakes. But for some reason, the pedal arm in this car had been pinned to the outside of the clevis, on the right-hand side. This concentrated all the force acting on the clevis pin on a single point, causing it to shear; and when the pin failed, the pedal slid past the rod that actuated the master cylinder. The result? No brakes.
Ford reacted instantly to news of the failure. Our Boss 302 was collected and sent away for a tear-down and inspection. The Mustang line was shut down, and every brake assembly checked. Ford also reviewed its process to ensure incorrect attachment of the brake pedal arm to the master cylinder clevis rod end could not occur. We’re told no anomalies were found. And we haven’t seen anything awry on the Mustangs we’ve checked since.
How the arm was misassembled on our Boss 302 tester remains a mystery to Ford, and to us. The only thing we can think of is this particular car’s master cylinder had been removed after it left the factory, and the incorrect connection to the brake pedal arm made when it was reinstalled, although we have no proof either way. Based on the evidence, we’re prepared to chalk this incident up to a freakish combination of circumstances.
Modern cars are amazingly robust and reliable. However, stuff can—and occasionally does—go wrong. That’s why we test.
Read more: http://blogs.motortrend.com/boss-mus...#ixzz1KbPq4reN
http://blogs.motortrend.com/boss-mus...est-14593.html
Originally Posted by Jaypod View Post
You sound like my buddies who have AMG's - Slam the gas, slam the brakes...
      04-26-2011, 01:33 AM   #2
Year's_End
Year's_End's Avatar
1243
12,446
Drives: 2020 Shelby GT350
Yeah, saw this article. They say the best reasoning for the failure would be a botched re-installation by some goon after fiddling with the car past its assembly finish point. That seems like the only plausible idea imo, considering this never happens in road tests.
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      04-26-2011, 01:33 AM   #3
Sylon
Sylon's Avatar
199
3,435
Drives: 2011 135i, SG/CR, 6MT, M-Sport
2011 135i  [9.20]
Sounds like a freak accident. And it seems like Ford jumped all over that like Lindsay Lohan on a necklace. Its just a good thing nobody was hurt and it appears to be an isolated incident.
One thing is for sure, somebody somewhere is getting fired.
2011 BMW 135i | Space Gray | ///M-Sport | BMW CCA #450291
Facebook / Instagram / YouTube / Twitter
      04-26-2011, 01:36 AM   #4
Year's_End
Year's_End's Avatar
1243
12,446
I just hope people don't start using this as some sort of reason to start bitching about Mustang reliability.
      04-26-2011, 10:01 AM   #5
OBI_agent
D to the X to the B!
OBI_agent's Avatar
United Arab Emirates
357
2,106
Drives: ABS,American bargain supercar
^^^+1000.
Like the GTR's failed trannies. Apparently, every GTR owner has that problem.
Anyway, I'm glad no one was hurt. After Insideline, I really like reading articles from Motortrend and it would have been a huge loss if something tragic happened. .
11 corvette C6
      04-26-2011, 10:58 PM   #6
blue2fire
blue2fire's Avatar
Cayman Islands
234
4,279
Drives: BMW 135i
It failed because they fiddled with it after production, must be embarrassing for Ford or not, based on their august reputation for quality products. Looking for Next Mustang thread in 5..4...3..2...
BMW CCA
Member #420568
Originally Posted by Gordon Murray View Post
Being a fan of Honda engines, I requested that they consider building for the F1 a 4.5 liter V10 or V12. I asked, I tried to persuade them, but in the end could not convince them to do it, and the McLaren F1 ended up with a BMW engine.
      04-26-2011, 11:06 PM   #7
ragingclue
One cam is enough
ragingclue's Avatar
136
6,801
Drives: VF
Talk about an "oh shit" moment....
      04-27-2011, 02:12 PM   #8
Sniz
Sniz's Avatar
680
10,584
Drives: e92 335 - gone // e36 M3 turbo
not joking!
I had something similar happen. Had a 4,000lb trailer hooked up to my truck with a large hot tub on top of it, so probably close to 5,000lbs hooked up. Stopped at a stop sign in the middle of a long uphill grade. Sitting at the stopsign all of a sudden the brake pedal went to the floor, truck started going backwards quick. Luckily no one behind me. I hit the gas hard, transmission was pissed about having to stop the backwards movement with that much weight but it didnt fail. Was able to gas it to the top knowing I had no brakes. Luckily found a flat area at the top and slowed to a crawl w the parking brake which was on its way out too.....barely was able to stop the truck from 10mph w the parking brake. Stopping it on that hill would have been futile.
Then took about 10 deep breathes and called a tow truck. Metal brake line blew.
that sucked.
back to the story, glad Ford jumped on the issue, hopefully it never happens again.
      04-27-2011, 08:01 PM   #9
pmeloche
pmeloche's Avatar
24
1,604
Drives: 2013 F25 X3 xDrive35i
Patrice
2013 F25 X3 xDrive35i Vermillion Red
      04-27-2011, 10:08 PM   #10
Impervious
UNC FTW
Impervious's Avatar
Pakistan
28
741
Drives: Black Sapphire 135i
Glad everything is okay, I'm sure this scare gave Ford a heart attack. Despite the brake failure it doesn't make me question Ford one bit. I know they want to take care of this especially with the bad press Toyota received.
