      10-12-2011, 08:58 PM   #1
HaiDef
27
416
Drives: M240i
Leveling a truck
Im about to purchase a 2007 Tacoma and want to level it out and buy bigger tires. Has anyone done this and know whats the most affordable route without sacrificing too much ride comfort since it will be my daily commuter and my bimmer a weekend car.
I see so many brands out there for levelers. Which brand is the most reliable? What tires give the most bang for the buck?
      10-12-2011, 09:23 PM   #2
ScaredOnce
Very Important
ScaredOnce's Avatar
20
450
Drives: 335xi (e92)
Lightbulb
Z-Deck Truck Leveler Click above to view
Sell Sheet
Improve loading dock operations safely and cost effectively.
Optimize your dock efficiency and safety by loading and unloading trailers above the building floor level. This minimizes interferences by the bumpers and building face. It reduces product damage and allows forklift drivers to have a better grade in and out of trailers. The revolutionary Z-Deck trailer lift raises trailer tires with a sloped deck that minimizes the angle of the lifting surface to keep the trailers from rolling away under their own weight. Designed to work with wall mounted vehicle restraints, the Z-Deck trailer lift matches the stroke of the lift cylinders to the vertical travel of a wall mounted restraint to increase the overall safety of the dock system.
• Increase Productivity
Eliminate floor interference by safety lifting trailer beds above dock level for full, unobstructed loading operations. • Low-Profile Design
2” Rear section slopes upwards to 8” at apex. No need for a costly in-ground pit. • Maximize Safety
The unique Z-shaped deck profile keeps tires on the deck and minimizes the slope the tires are supported by. Profile keeps tires angled towards dock to level at maximum raise. • Simple Design
Robust construction and dual lifting cylinders provide reliability and safety. • Full-width Trailer Access
Elevate trailers above floor level to service wider trucks with full-width loads. • Improved Trailer Alignment
Integral Wheel Guides center trailer
on docks, minimizing product and
door damage.
“Ski-Slope”- the hinging action of a typical truck leveler pivots the front of the ramp and raises the rear causing a negative angle in relation to the dock. The Z-Deck Truck Leveler by Leum Engineering, Inc. is the only truck leveler on the market that can solve this very basic, yet dangerous condition. The mid-level profile slopes back toward the dock when stored creating a much safer condition. Due to the shock loads caused by forklift operations, a vehicle restraint is always safe practice.
The Z-profile also increases the lift of axles that are further away from the dock face with a shorter lifting platform.
Unique “high-lift” hinges at the front of the deck arc towards the dock creating a net vertical lift, minimizing the push away from the dock and again making the dock interface safer.
The integral wheel guides center the trailer to optimize the door openings and minimize product damage. Using the lifting function to position the trailer bed above dock levels
gives the operator full width access to the load and minimize product damage and
increase productivity.
Please Note: Unless specifically noted on quotation, all electrical including hook-up is the
responsibility of others. Patent pending
• Nominal Dimensions
The Z-Deck platform is 11’ wide x
18’ long • Capacity
AASHTO HS20-44 plus forklift for
60,000 lbs • Construction
The unit is constructed out of structural carbon steel consisting of 1/4” thick deckplate and structural HSS tube sides. The center tire surface is level from side to side to minimize interference with air ride brake canisters. The cylinders are nominally 16” stroke with a travel at the rear of the platform of 24”. • Hydraulics
Dual 4” x 16” stroke cylinders with spherical bushings top and bottom
to ensure long cylinder seal life. • Loading Dock Bumpers
Two 10” wide x 36” high steel faced dock bumpers are required (provided
by others) • Power Requirements
480v/3ph power with a 5 HP 3phase hydraulic power unit. • Safety Features
• Z-Deck Profile • Hydraulic Velocity Fuses • Side toe guards • Wall mounted retraint recommended • Service Range
2” to 15” lift © Copyright 2008 Leum Engineering, Inc. All Rights Reserved. 952.401.0127 Sales@LeumEngineering.com
      10-12-2011, 09:40 PM   #3
HaiDef
27
416
Drives: M240i
um? i meant lifting a truck.... lol
      10-12-2011, 10:14 PM   #4
yakev724
yakev724's Avatar
244
3,563
Drives: 15 S3
Originally Posted by ScaredOnce View Post
      10-12-2011, 10:40 PM   #5
Blake
795
4,647
Drives: Chevy Aveo
Wtf?
      10-12-2011, 11:02 PM   #6
fokus45
43
Drives: little blue dune buggy
Look at Icon kits. They make some really good stuff.
      10-13-2011, 12:36 AM   #7
scollins
Bootleggin' 'n Gunrunnin'
scollins's Avatar
144
2,372
Drives: 2024 X3 M40i
www.tacomaworld.com
Have a look over there. All kinds of info on leveling, lifts, tires, etc.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles
2019 Ford F450 STX, Oxford White
2013 Ducati Multistrada Touring S, Red
      10-13-2011, 10:36 AM   #8
M3Monster
15
70
Drives: 2011 E90 M3
I'd go with camburg.com they have a sway away coil over and I think a fox coil over that easy bolt in that will give you 1-3" lift. It's valved for the truck and ready to go.
      10-14-2011, 07:44 AM   #9
Gravy
Look away, look away, look awa....
158
Drives: 2007 335i sedan m/t bone stock
i did my own body lift on my 95 z71 and the newer leveling kits that Ive seen basically consist of a small spacer with bolt holes that go under/above (depends on the truck) your front coil springs. Nothing to it if you've got any sense whatsoever. Tires are a diff story. I like going for wider setting tires but the rims make the biggest difference.
I aint got time for all that "proper" grammar nonsense.
ROLL TIDE!
