05-29-2007, 09:28 PM | #1 |
A^M=G is nothing w/o the Power of ///M
![]() 173
Rep 1,817
Some More Physics for you smart guys.
Ok since i got such great help from my last thread here is another
![]() Problem 1: Ball A is dropped from the top of a building. One second later, ball B is dropped from the same building. Consider the balls while they are both in flight. You may ignore air resistance. Which statements are true about this situation? True False- Both are in free fall True False- As time progresses, the difference between their accelerations increases True False- As time progresses, the distance between them stays constant True False- As time progresses, the difference between their velocities decreases True False- Ball B will hit the ground after ball A Problem 2: You bring a large cannon along with you on a voyage to a distant planet. You set the cannon on a high cliff and you fire a cannonball horizontally off the cliff into an ocean. The cannonball follows projectile motion until it splashes into the water. Which of the following factors will determine the time that the cannonball is in flight? You should ignore atmospheric ("air") resistance. yes no- height of cliff yes no- mass of cannonball yes no- planet's acceleration due to gravity yes no- initial velocity of cannonball yes no- radius of cannonball Problem 3: Three forces in the x-y plane act on a 4.50 kg mass: 15.10 N directed at 51o, 9.00 N directed at 142o, and 5.60 N directed at 219o. All angles are measured from the positive x-axis, with positive angles in the Counter-Clockwise direction. Calculate the magnitude of the acceleration. I got the answer for this: 3.086 m/s^2 Calculate the direction of the resultant force using the same sign convention as above (in degrees). But how do i do this? Thanks Guys ![]()
Indianapolis Red BMW ///M5
05-29-2007, 11:26 PM | #2 |
![]() ![]() 266
Rep 6,664
This stuff is easy.. If no one helps you out by tomorrow when I get to work, I'll help you out then..
![]() E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
05-29-2007, 11:35 PM | #3 | |
![]() 173
Rep 1,817
A fire helicopter carries a 561 kg bucket of water at the end of a 24.9 m long cable. Flying back from a fire at a constant speed of 43.6 m/s, the cable makes an angle of 48.4° with respect to the vertical. Determine the force of air resistance on the bucket. and this: A 2016-kg elevator moves with an upward acceleration of 1.86 m/s2. What is the tension in the cable that supports the elevator?
05-29-2007, 11:47 PM | #5 |
![]() 173
Rep 1,817
yea i just dunno how to find the angle.
05-29-2007, 11:55 PM | #6 |
![]() ![]() 163
Rep 6,158
use trig to break each vector into X and Y componants
then you can add them easily you know the length of the hypotenuse of the triangle and one of the angles so you can find the length of the other 2 sides (which are the x,y componants) what grade or level is this phyiscs BTW? |
05-29-2007, 11:56 PM | #7 |
![]() ![]() 163
Rep 6,158
05-29-2007, 11:59 PM | #8 |
![]() 173
Rep 1,817
05-30-2007, 12:01 AM | #9 | |
![]() 173
Rep 1,817
This is level one college physics ![]()
05-30-2007, 12:02 AM | #10 |
![]() ![]() 163
Rep 6,158
hmm do they give you any other info?
not sure what the difference is between force and tension? is tension like the force per area of the cable? alot ot times they F with the units on problems to make it harder too, maybe that's part of it? |
05-30-2007, 12:02 AM | #11 |
Powered By 36DD
![]() 376
Rep 7,369
my brother is a chemistry/physics teacher....i'm sure he knows.
but me......i got a C+ in physics.....
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
05-30-2007, 12:03 AM | #12 | |
![]() ![]() 163
Rep 6,158
you have the X and Y componants, (2 sides of the triangle) use trig to find the angle it's another f=ma question |
05-30-2007, 12:13 AM | #13 | |
![]() 173
Rep 1,817
05-30-2007, 12:16 AM | #14 |
![]() ![]() ![]() ![]() 58
Rep 960
#3
i got -.4315 for accel in x direction 3.05592 for y direction magnitude is like you got 3.086 angle i got is 98.038 give that a shot
05-30-2007, 12:19 AM | #15 | |
![]() 173
Rep 1,817
but still stuck on the other one
05-30-2007, 12:20 AM | #16 |
![]() 173
Rep 1,817
05-30-2007, 12:23 AM | #17 |
Rep 960
sorry, look at my edited post above
05-30-2007, 12:33 AM | #18 | |
![]() 173
Rep 1,817
05-30-2007, 12:34 AM | #19 | |
![]() ![]() 163
Rep 6,158
I'm not sure from your pic which vector is the result, but hopefully this helps |
05-30-2007, 12:35 AM | #20 | |
Rep 960
![]() do you have aim, i can better explain it to you on there, but if you want i can explain in here, let me know
05-30-2007, 02:16 AM | #21 |
![]() ![]() 182
Rep 2,355
So this is level one college physics?? I should be set....not to far from what i learned in physics class actually i learned much of this...this is good news..what college do you attend BTW??
2006 E46 M3 ZCP 6SPD-Interlagos Blue - 6SPD - SSK - AA Headers -AA Tune - Navigation w/ Splashscreen Mod - 3M Crystalline Series 60 - Carbon Splitters - Swissvax Treated - Bridgestone
2012 Yamaha FZ8 - Matte Black/Grey - Michelin Pilot Pure 2CT - Vortex Rear Sets - Yoshimura R-77D & Fender Delete - Spectro Race Oil - GP Reverse Shifting |
05-30-2007, 03:28 AM | #22 |
![]() 173
Rep 1,817
Yea this is about the first week of level one college physics. I go to George Washington University in DC. Where are you going?
