BMW X3 G45
Welcome to the ultimate G45 BMW X3 community
956VIEWS
11REPLIES
3APPRECIATES
7ACTIVE PEOPLE
3 hours agoLAST POST
04-10-2026
04-10-2026
robe033 user avatar
robe033
Second Lieutenant
211 REP
Can anyone check if there is an option in Doors to disable Open on approach
Appreciate0
2 days ago
2 days ago
robe033 user avatar
robe033
Second Lieutenant
211 REP
Dolgo posted on www.motor-talk.de
Here is a focused, technical delta analysis of the latest software version (~03/2026 vs. your 11/2025) – not as a feature list, but along the lines of the actually changed control loops.
1. Longitudinal dynamics: Recuperation ↔ Brake ↔ Cruise control (core change)
What's new
  • Predictive lead time : Delay is "built up" earlier, before the speed is exceeded.
  • Continuous blending : Recuperation and hydraulic braking often run in parallel (instead of "either/or").
  • Flatter deceleration curve : fewer peaks, more consistent braking torque.
How this manifests itself
  • Downhill: less readjustment, hardly any "re-braking"
  • In ACC: earlier, gentle delay instead of later, stronger interventions.
Technical Interpretation
  • stronger coupling of:
  • Map data (gradient/topology)
  • Target speed (ACC/Limit)
  • Current vehicle status (SoC, Grip)
  • The target variable shifts from "maintaining target speed" to
  • "Achieve target speed without overshooting"
2. Recuperation: Torque management (VA/HA) + SoC handling
What's new
  • Finer torque distribution between front and rear axles
  • Earlier regenerative braking activation when a gradient is detected
  • Softer SoC derating (less abrupt throttling at ~80–100%)
effect
  • More stable deceleration on varying friction coefficients
  • less “recuperation breaks down → brake engages”
  • Improved control during long descents
Technically
  • Recuperation is used as a vehicle dynamics actuator (not just energy recovery)
  • Reduction of slip peaks by distributing the braking torque
3. B- vs. D-mode: State logic sharpened
B-mode
  • Characteristic curve smoothed , same maximum power, but:
  • earlier start
  • less steep inclines
  • Result: more controlled , less "jerky"
D-Mode (biggest win)
  • clearer conditions (sailing or recuperation, less back and forth)
  • stronger integration of:
  • Map profile
  • Cruise control
  • In the ACC, it acts almost like a "predictive soft B".
Net
  • B = precise tool for delay
  • D = Default for efficiency , significantly improved
4. Mechanical brake: deliberate early mixing
What's new
  • Small hydraulic components are added earlier, even though recuperation would still be possible.
Why
  • Comfort filter (no harsh transitions)
  • Stability (especially in wet conditions/curves)
  • Reserve power (faster response than regenerative braking alone)
consequence
  • subjectively "smoother"
  • Objectively speaking: slightly less regenerative braking maximization , but more robust.
5. Stability logic under delay (underestimated)
the change
  • Cross-axle distribution of braking torque (including recuperation) is used more actively.
  • The front axle acts more as a stabilizer (pitching/yaw moment).
effect
  • quieter vehicle at:
  • gradient + curve
  • changing grip
  • Fewer interventions by the ESP as a "last step"
6. Charging / Power path (relevant if you are using DC)
Improvements
  • more stable DC handshake sequences
  • Fewer dropouts / retries
  • more consistent power consumption
Classification
  • No peak performance gain, but higher reliability → often faster in real-world use.
7. Navigation & Prediction
the change
  • Greater emphasis on:
  • Topography (slope/gradient)
  • Traffic
  • Target speeds
Effect on driving behavior
  • previous regenerative braking in D-mode
  • ACC “thinks ahead”, not just reactively
8. Side effects / Trade-offs
  • more conservative procedures (earlier, but gentler)
  • occasionally:
  • Delaying something "too cautiously"
  • Less transparency:
  • It is harder to recognize exactly when mechanical braking occurs.
9. What explicitly
not
Part of the update is
  • no new sensor technology
  • no higher level of autonomy
  • no significant increase in range or performance
→ Calibration remains within existing hardware
10. Summary
The update shifts the focus from:
Maximum recuperation / reactive control
to:
Predictive, mixed control with stability and comfort priority
For your specific situation (mountains, longer descents, conscious SoC management), this means:
  • fewer interventions of the mechanical brake in "stages"
  • More stable latency at ~80% SoC
  • Noticeably calmer behavior in ACC downhill mode
Appreciate3
2 days ago
2 days ago
MontyB1 user avatar
MontyB1
Colonel
2,283 REP
2.5K POSTS
Lots of tweaks and improves there, nothing on any fixes to and internal software.
Appreciate0
2 days ago
2 days ago
catalyst86 user avatar
catalyst86
New Member
56 REP
How can we update?
Appreciate0
2 days ago
2 days ago
robe033 user avatar
robe033
Second Lieutenant
211 REP
catalyst86 wrote
How can we update?
At dealer only, mine was on hold until updated, now have a recall for another update, booked into dealer next month
Appreciate0
2 days ago
2 days ago
VincentHannah user avatar
VincentHannah
Second Lieutenant
257 REP
Why don't they just make these over the air updates?
Appreciate0
2 days ago
2 days ago
MontyB1 user avatar
MontyB1
Colonel
2,283 REP
2.5K POSTS
They will but at first the often make the dealer update only in case of issue they can help resolve issues, then they roll them out OTA. On the X1 forum it wasn’t unknown for updates to brick a car, very rare and we have had no issues but it’s not a zero risk especially early on.
Appreciate0
Yesterday
Yesterday
willows user avatar
willows
New Member
Netherlands the
17 REP
FYI my car shows version 03/2026.34. Delivered 4 days ago so not sure if this was already in the car or updated OTA.....
Header of this post is a bit confusing as sw versions are not written as 2026.03.32 but as 03/2026.34....
Appreciate0
Yesterday
Yesterday
xins01 user avatar
xins01
New Member
15 REP
Has anyone seen the details/summary of the sw updates?
There is a ”button” in the car bur it does not work in 03/2026.32
I got a recall so I guess that my car will get an update tomorrow
Appreciate0
Yesterday
Yesterday
TerraWan user avatar
TerraWan
New Member
6 REP
I am still on the 11/2025 with no recall or OTA updates pending...
Appreciate0
11 hours ago
11 hours ago
catalyst86
New Member
56 REP
Users of the new version at least let us know if there are changes in the functionality, such as:
  • Does "automatic lock/unlock by approaching" work with the key fob?
  • Does the cooling of the wireless charger work?
  • Can you control the A/C settings of the rear seat from the main screen?
Those three are the stuff that I am lacking most.
Appreciate0
3 hours ago
3 hours ago
xins01 user avatar
xins01
New Member
15 REP
Today I got 03/2026.34 installed. No details whats fixed or new in this version
Appreciate0
