Has anyone managed to record a parking routine
I cant find to button to record
614VIEWS
13REPLIES
5APPRECIATES
7ACTIVE PEOPLE
04-21-2026LAST POST
04-15-2026
04-15-2026
04-15-2026
04-15-2026
Same issue here. My standard 2025 X3 (USA based) had the record path option, but my iX3(UK based) doesn’t have the option. I was wondering if it was a regional restriction….
robe033
04-15-2026
04-15-2026
Do you have parking professional? Not just parking plus.
Isn't it all part of that.
04-15-2026
04-15-2026
You might be right Reverse Assistant Pro only comes in the Pro pack not plus, maybe that is needed have you both got that and the remote parking?!?
robe033
04-15-2026
04-15-2026
MontyB1 wroteYes bothYou might be right Reverse Assistant Pro only comes in the Pro pack not plus, maybe that is needed have you both got that and the remote parking?!?
I have used it to park in a bay - excellent
Remote parking works fine
I have spoken with connected drive, they confirm there should be a button to record, but there isnt
MontyB1
04-15-2026
04-15-2026
VincentHannah wroteYes I have parking professionalDo you have parking professional? Not just parking plus.
MontyB1
04-15-2026
04-15-2026
Will a parking routine work inside an underground garage?
04-15-2026
04-15-2026
svenb wroteI believe it would if there was a way to record itWill a parking routine work inside an underground garage?
04-16-2026
04-16-2026
It doesn't work on slopes (or at least it didn't, in the iX)
04-16-2026
04-16-2026
VincentHannah wroteHuh, it worked for me on an incline. Probably depends on how steep.It doesn't work on slopes (or at least it didn't, in the iX)
04-16-2026
04-16-2026
I have just read the recording of a parking routine is done in Drive Recorder - Will try tomorrow and report back.
On www.motor-talk.de/forum People have heard it will become available in July OTA
04-21-2026
04-21-2026
The recording path function requires GPS - in underwound garage it may have GPS access problem.
04-21-2026
04-21-2026
robe033 wroteI have had a reply from Connected DriveHas anyone managed to record a parking routine
The “record new path” function will be coming with 07.2026 software, so unfortunately this function isn't available yet
MontyB1
04-21-2026
04-21-2026
Well at least you know you aren't going mad, I suspect that will be the level mine comes with so a few fixed included. I'm pretty sure they are going to be pretty hot on id X to get on top of things as its looking like its going to be quite widely used.
