Hello,
Please i need help.
Would you please share the pinout of RAM base standard, or help to identify the pin numb of front speakers in base audio system.
Thank you for help
Not sure what your goal is, but this harness may help if you want to add a sub, or you can use it to test pin out. I have used this harness in multiple of my BMW's. He is a great guy, a member at Bimmerforums that started the business. I recently tested the HK harness for him for the G45 X3, which should be releasing soon.
HiFi (Option 676) Archives - Technic PNP
Hello,
Thank you for your answer.
So I have upgraded my base system. i have changed all speakers by matchup with tweeters and added musway m6v4 amp using the kit MPK m6 bmw RAM wich seems to be plug and play .
But all speakers are amplified by the musway except the front wich still driven by the ram directly. Like the kit bypass the front spk.
So i need the pinout of the base RAM to identitify wich pin is powering the front speaker to adapt the P&P kit.
The sub and rear speakers are powered correctly by the amp.
Curently the p&p kit links the pin 2to 5 to front speakers. But the pin 2to5 are not wired.
Thank you for your help.
Regards
Have something to add?
Join the community and share your thoughts.
