      08-20-2008, 11:51 AM   #23
E90SLAM
Supreme Allied Commander
E90SLAM's Avatar
Hong Kong
2053
61,781
Drives: A BBS WHORE
So many choices now...M3, RS5, C63, IS-F.......
      08-20-2008, 12:43 PM   #24
Year's_End
Year's_End's Avatar
1267
12,446
Drives: 2020 Shelby GT350
Originally Posted by slapmyfro View Post
the rs4 weighs nowhere near 3400 pounds
its around 3650
dont know where you got your info from
Yeah I already pointed out that the info I got was false. Good job mate.
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      08-20-2008, 12:43 PM   #25
audiprotein
audiprotein's Avatar
18
439
Drives: Audi a4
I think it would be a v8. If it had FI, rs5 would have more ponnies/tq than that.
L.E.T.S. G.O. H.A.W.K.S.
      08-20-2008, 12:52 PM   #26
southlight
Moderator / European Editor
southlight's Avatar
1637
6,752
Drives: X3M
Originally Posted by hks786 View Post
Engine:
4.2 V8. 470bhp, 500Nm
7s S-tronic
Weight:
1702kg. It looks like it's going to be more nose heavy than the S5.
Design:
Test mules are running around with the new front bumper. It has big side intakes like the A3 Clubsport. Should be interesting!
On a side note, I seen a silver S5 with RS4 wheels today. It looked MEAN! I can only imagine the presence the RS5 will have on the road.
Source? Pictures?
Best regards, south
Those forums...WHY NOT?
JOIN THE 6MT CLUB GROUP
      08-20-2008, 01:14 PM   #27
swamp2
swamp2's Avatar
663
10,404
Drives: E92 M3
Originally Posted by footie View Post
Is it known whether the engine is still N/A or FI?
If it's N/A and still 4.2L then to get that amount of power would require a higher rev range. The new DSG is capable of 550Nm and 9000rpm, does this mean the new engine is revving closer to that limit, says 8600rpm.
I read somewhere that Valve-lift can increase torque by up to 12%, that would improve the 75ft/lbs per litre of the RS4 engine to 84ft/lbs, that is getting pretty close to the 90ft/lbs being suggested by hkz786. But then look at the S5 engine, it's at 77ft/lbs, add the same 12% improvement and you are at 86ft/lbs. Maybe this figure is starting to look a lot more believable than first thought.
Want to bet if it will be anywhere close to 90? I'd bet today, knowing basically "nothing" that it will not be above 85 ft lb/l. I'd almost bet at 80 as well but I am conservative. This all assumes no FI.
      08-20-2008, 04:11 PM   #28
footie
footie's Avatar
1239
8,034
Drives: i5M60
I was only showing how such a story might have been put about and why it's almost believable. Valve-lift is meant to improve torque by up to 12% (might be marketing talk this figure) but the real facts are that the S5 makes 440Nm without it and an improvement of 12% equals 492.8Nm.
      08-20-2008, 04:14 PM   #29
down4it
67
1,743
Drives: E92 335i
Yay, another 13 second audi on the road...
      08-20-2008, 04:21 PM   #30
T Bone
T Bone's Avatar
566
4,021
Drives: 2008 335xi Coupe
If the 470 hp / 4.2 liter motor numbers are to be believed, I would bet against natural aspiration....this is 112 hp / liter.
I am betting on light turbos somewhere between a BMW N54 and a naturally aspirated engine. Something like 5-7 psi so much of the engine's characteristics would somehow look like a naturally aspirated engine.
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
      08-20-2008, 04:30 PM   #31
footie
footie's Avatar
1239
8,034
Drives: i5M60
That sounds a lot more believable to me and if executed correctly will still have the behaviour/feeling of a N/A engine. If true this might be what we may expect if BMW chose to go the FI route for future Ms.
P.S.
On a different point, the F430 produces more per litre than that so why wouldn't it be possible for someone like BMW or Audi to do similar. I don't believe the crank has any bearing on this though I am not certain, the only thing I do know is the RS4 engine has the highest piston speed on any production engine.
      08-20-2008, 04:37 PM   #32
T Bone
T Bone's Avatar
566
4,021
P.S.
You can throw in the GT3 engines in there. To wring out that type of power output would mean stressing a normally aspirated engine hard and this may be unacceptable from a warranty / reliability perspective.
The S85 V10 / S65 V8 could easily deliver more power by increasing revs and/or tuning the engine to deliver more torque at higher rpms at the expense of low end torque....in the end it is a trade off.
Light pressure turbo cars may be the ugly compromise that M may need to make but I would expect this from an ///M car
  • Better volumetric efficiency at low rpms
  • Turbos provide better breathing at high rpms to compensate for making the engine perform better at low rpms
  • Have it rev freely as it does today
  • Perhaps have KER technologies in there
      08-20-2008, 04:48 PM   #33
footie
footie's Avatar
1239
8,034
Drives: i5M60
Revs aren't the issue, Honda have been producing engines revving to 9000rpm with minimum warranty problems.
I agree that the likelihood is it will be FI but which form, will it be turbos or supercharger, I don't know which would allow the engine to rev highest, a guess would be the supercharger mainly because MTM have their own RS4 with a compressor still revving to the same as the normal car.
P.S.
I don't want to side track this discussion but in a way it is relevant because of the FI debate. Do you have any idea as to how much the RS6 engine is truly capable of producing, reliably?............wrong, it's meant to be close on 900hp.
I know I couldn't believe it either but it's meant to be true.
      08-20-2008, 05:01 PM   #34
OBI_agent
D to the X to the B!
OBI_agent's Avatar
United Arab Emirates
377
2,106
Drives: ABS,American bargain supercar
Off topic, I saw a 4.0 TFSI V8 engine in 'Audi's upcoming engine list'. Could that be a candidate for RS4/RS5 engine bay>? I dunno if it's turbo or supercharged but it does say TFSI
11 corvette C6
      08-20-2008, 06:29 PM   #35
hks786
United Kingdom
2332
5,364
Drives: *
I actually thought when the RS6 came out that the RS5 will have a 4.0 TFSi based on the V10TT. It was just an idea but it would give great figures! At this time even the details I gave have a posibility to be wrong but I've heard from a couple of good sources. Never forget that Audi have been known to try more than 1 setup in their prototypes
      08-20-2008, 06:52 PM   #36
KonigsTiger
Racying Dynamics
KonigsTiger's Avatar
120
4,369
Drives: E92M3 RS46 Club Sport, others
+1
      08-21-2008, 03:27 AM   #37
footie
footie's Avatar
1239
8,034
Drives: i5M60
I heard about this engine, it's going to feature in the A6 and A8, must likely the Q7 as well at some point. There won't be any weight saving over the 4.2 currently used but there will be a big gain in power, torque and most important economy and C02 levels.
If there was ever an engine to push BMW M-Division down the FI route then this might be it.
      08-21-2008, 11:14 AM   #38
OBI_agent
OBI_agent's Avatar
377
2,106
Just like the M3's V8 is based on M5 V10....hmmm.....I certainly hope so!
Fingers crossed....hope they do it.....TT or SC V8 would be awesome
11 corvette C6
      08-21-2008, 01:18 PM   #39
LI E90
LI E90's Avatar
146
2,086
Drives: E90
leftlanenews.com.
Yesterday afternoon in the American southwest desert, our spy phtographers spotted an almost entirely undisguised Audi RS5 high-performance coupe. Aside from the absence of oval tailpipes - which would make any efforts of hiding what it is entirely null and void - this is the 2010 Audi RS5.
It still remains unclear just what motor is under the hood, but the latest rumors suggest a 4.0 liter turbocharged TFSI V8 putting out an impressive 470 horsepower. The RS5 will certainly challenge the BMW M6. Though we don’t know any specifics on an estimated debut, we would estimate that it will show up soon at an auto show and be on sale late Spring or early Summer 2009 as a 2010 model.
August 21, 2008
2013 MB C300 4matic
2014 Ford Explorer Ltd
1973 Jeep Commando
      08-21-2008, 02:35 PM   #40
southlight
southlight's Avatar
1637
6,752
Drives: X3M
Originally Posted by southlight View Post
Source? Pictures?
Here are some pics:
[source: http://www.motorauthority.com/news/c...-2010-audi-rs5 ]
Best regards, south
      08-21-2008, 03:02 PM   #41
footie
footie's Avatar
1239
8,034
Drives: i5M60
Those are intercoolers at either side. Well there you are, it's turboed.
Does this meant it's still using the 4.2L from the RS4 or is it a new engine, maybe the 4.0TFSI that to take up service in the A6 and A8.
      08-21-2008, 09:36 PM   #42
OBI_agent
OBI_agent's Avatar
377
2,106
Damn............it hope it's turbo but it could be supercharged too..Anyway...whatever it is ....I hope it is force induction!
11 corvette C6
      08-22-2008, 09:52 AM   #43
KonigsTiger
Racying Dynamics
120
4,369
Yea, those are intercoolers, it sure looks like its FI to me. Not liking the spoilers etc... that much though. I thought it would be much, much nicer. Lights are funny too. Oh well, I suppose its going to improve.
      08-22-2008, 10:20 AM   #44
Greeney
Greeney's Avatar
235
3,857
Drives: Jerez E90 M3
Look at the size of those intercoolers, okay this car is going to be MEANNNNN
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 |
