01-24-2016, 07:01 PM | #45 | |
253
Rep 658
Not exactly rocket science.. |
01-25-2016, 01:54 AM | #46 | |
83
Rep 329
The Oil Temperature is not as important as you might think in that matter. It takes up to 10 seconds for regular oils to lubricate the whole cylinder. When it is cold this process takes about 20% longer. Thats the main difference, this is where the higher wear and tear occurs (compared to warmer temperatures). Now even in summertime, the oil temperature should be around 180°F / 80°C before reving the engine. Yes this will take longer in winter but the tear will be insignificant higher. Get in the car, start, buckle up, turn on the radio and drive off gently, stay under 2000/min. What really matters is the cooling liquid temperature. Why? If you imagine an engine block you have different materials with different thermal expansion coefficients. Piston heats up faster than the the cylinder, and there is this lazy,lazy cooling liquid around the cylinder in the engineblock. For non rocket scientists: Its basicly a phallus getting bigger and bigger much faster than the counterpart, you can put as much high performance lube on it, it will still hurt. The only way to prevent this, is by installing a auxilary heating, and those are really not expensive. I have it in my 530D, and will never go back. Webasto for example are very good systems, and are the OEM sytem supplier for BMW. (Among sunroofs, climate systems, and the Roofs for BMW Convertibles such as my E89) http://www.webasto.com/us/markets-products/car/ Last edited by Desmo85; 01-25-2016 at 01:59 AM.. |
01-25-2016, 02:39 AM | #47 |
3829
Rep 5,776
Yeah..don't know what you guys are talking about or why you would want to live in a place where ice cubes live. When I go out in the morning on a really, really cold day, like 45F., I turn on the heated seats and steering wheel and just drive off.
01-26-2016, 04:02 PM | #50 | |
83
Rep 329
01-31-2016, 06:32 AM | #51 |
Rep 39
I always warm mine up for at least a few minutes.
One time I turned my 335 on and drove it straight away cold and may have driven it a bit too aggressive and had to replace a solenoid LOL |
01-31-2016, 01:47 PM | #52 |
19390
Rep 19,809
Not really. There are not two sides to every point.
01-31-2016, 01:50 PM | #53 |
19390
Rep 19,809
and cold bearing clearances vs. warm bearing clearances...
01-31-2016, 01:50 PM | #54 |
10804
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Actually, there are at least two sides to every point. There is a right side and a wrong side at a minimum.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
01-31-2016, 01:54 PM | #55 |
19390
Rep 19,809
Being wrong is not a point; it's just incorrect.
01-31-2016, 02:03 PM | #56 |
10804
Rep 8,852
You have a point, even if it is incorrect.
01-31-2016, 03:56 PM | #57 |
19390
Rep 19,809
But it is correct.
One may have a side to a point that he might survive jumping off a 50 foot bridge on to a concrete roadway with semi truck traffic travelling at 70 MPH on it, but he'd be wrong.
01-31-2016, 04:20 PM | #58 | |
10804
Rep 8,852
I'm done here.
02-03-2016, 06:39 PM | #59 |
382
Rep 1,497
Depends. My house is 2blocks off the expressway. I leave for work at 5am everyday. To get onto the expressway I have to press the gas.doing this on a cold engine that's been turned on in the last 30seconds feels very very bad, and the csr doesn't like it. I prefer 5-10min of idling before this happens
