05-29-2019, 06:47 PM | #1 |
![]() ![]() 562
REP 363
Bavgruppe 3/4 rings
My headlights were in heavy need of a rebuild; the lenses had oxidation from the sun, and I always hated how the rings looked. I decided to bite the bullet and rebuild them myself. As an FYI this is not a DIY, I found a couple good videos on YouTube and a post on this forum for that.
What I ordered: > Bavgruppe 3/4 Rings > Carbon Fiber eye lids. > ZKW-R Lenses > Bimmer Jake lens covers. > Butyl Rubber/glue. > Goretex patches As for paint and epoxy: > Rust-Oleum self-etching primer > Rust-Oleum plastic Semi-gloss paint > Rust-Oleum high gloss > JB Weld ClearWeld Quick Setting Epoxy (this was KEY) Here you can see a before and the oxidation on the top. ![]() and here are some afters: ![]() ![]() ![]() Cameras have a hard time capturing just how bright these are. Here is an almost dark room at sunset with just the rings on: ![]() Here you can see a comparison between the ZKW-R lens and the original where the right light is the new lens and the left light is the original: ![]() I then had a shop near me clear wrap them with XPEL -- that stuff is practically invisible! And it self-heals too: ![]() close-up of the corner/edge of the clear-bra ![]() ZERO orange peel: ![]() And finally here is how they turned out: ![]() ![]() ![]() An album with misc. shots: View post on imgur.com Was it complicated? Not really -- but they do leave ZERO margin for error; you have to be spot-on with how you place the outer ring on the shroud and how you cut the mounting points for clearance. It was very time consuming. I took four days and lots of breaks in between to spend time with wife and daughter after my business trip. At the end, I found it kind of relaxing. I did one headlight at a time, made a couple mistakes on the first one, adjusted and corrected them on the second headlight and they came out perfect. I highly recommend two things: replaces your lens covers; I cannot believe how many people go through all this trouble and don't do it. 2. Take your time, enjoy it; the results are so rewarding. Any question, feel free to reach out. Last edited by Silos; 05-30-2019 at 12:45 PM.. |
05-29-2019, 09:43 PM | #5 |
![]() ![]() 562
REP 363
05-30-2019, 04:31 PM | #6 |
![]() 101
REP 274
Can you please provide links to the resources you used for this retrofit? Looks awesome!
2013 Alpine White E92 M3 ZCP - IND Paint Matched Reflectors
05-30-2019, 04:37 PM | #7 | |
![]() ![]() 562
REP 363
YouTube: and the post: https://www.m3post.com/forums/showthread.php?t=1437056 |
luckyse7en101.00 |
04-28-2020, 05:29 PM | #8 |
//Mdicted
![]() 364
REP 9,989
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
Subscribed
