BMW X3 G45
Welcome to the ultimate G45 BMW X3 community
1.6KVIEWS
17REPLIES
9APPRECIATES
10ACTIVE PEOPLE
04-09-2024LAST POST
04-07-2024
gac user avatar
gac
Second Lieutenant
United Kingdom
136 REP
Does it screw anything up? I'm lazy, and I have the key fob in my pocket, so I use the powered function all the time. Unfortunately my teenager has the attention span of a goldfish so if the tailgate isn't fully open within 0.1 seconds of her pushing the button in the handle/boot trim then she's trying to drag it upwards/downwards.
I'm assuming that since it's powered, lifting it manually is an "emergency" only activity when you really have to?
Appreciate0
04-07-2024
xenon user avatar
xenon
Major General
1,570 REP
8.3K POSTS
No it’s on a sliding clutch - lifting it manually does no harm.
Appreciate2
04-07-2024
gac user avatar
gac
Second Lieutenant
United Kingdom
136 REP
Cool, good to know. It'll still bug the crap out of me but at least I know there isn't a repair bill in my future from an impatient teen.
Appreciate0
04-07-2024
Ennoch user avatar
Ennoch
Colonel
2,813 REP
2.5K POSTS
To be fair I'm with her, the speed powered tailgates open at makes me die a little inside, every single time. Sometimes it's handy, I'll grant it, but most of the time it's just an irritation. I can't bring myself to open it manually like your daughter though, I just silently scream if I haven't managed to open it on the way to the car with the fob.
Incidentally it took me over three years of having the car to discover I could also close the boot with the fob. Something about RTFM?
Appreciate0
04-08-2024
gac user avatar
gac
Second Lieutenant
United Kingdom
136 REP
Oh yeah, I get it too. I obviously have the advantage that the fob is in my pocket, so assuming there isn't someone stood behind the car I can open it as I'm walking back to it/leaving the house so it's done when I get there, then push the button and it's closed by the time I'm sat in the car ready to drive off.
I was just curious cos so far I've told her to keep her mitts off, on the grounds that if her unwillingness to wait 5 seconds costs me hundreds/thousands in new boot struts then I will be (paraphrased) "slightly cross".
I also only just found you can close the boot by holding the fob, and only just found there's an interior button. I have only had the car a month and a half though rather than three years, so ignoring the manual is still clearly the way to go!
Appreciate1
04-08-2024
Pond user avatar
Pond
Colonel
3,126 REP
2.9K POSTS
Could someone please post that manually lifting the tailgate WILL definitely damage it?
Then I can show the post to my wife, as she keeps 'forgetting' it is powered.
Ta very much. ;)
Appreciate1
04-08-2024
Ennoch user avatar
Ennoch
Colonel
2,813 REP
2.5K POSTS
gac wrote
...then I will be (paraphrased) "slightly cross".
I think she's just being a teenager in that case :lol:
Where TF is the interior button?!
Appreciate0
04-08-2024
archerz user avatar
archerz
First Lieutenant
United Kingdom
378 REP
under the light switches on the right of the steering wheel.
Shown here but for left hand drive, obviously on the right in the UK :)
https://f30.bimmerpost.com/forums/showthread.php?t=1132318
Appreciate0
04-08-2024
Markos ZimZimma user avatar
Markos ZimZimma
Second Lieutenant
United Kingdom
127 REP
Ta very much. ;)
I keep a close eye on mine when she use the boot as she has often pushed/pulled it manually :(
Appreciate0
04-08-2024
gac user avatar
gac
Second Lieutenant
United Kingdom
136 REP
Just above the bonnet catch and the OBD port. Both of which I've used, and didn't notice the boot button until yesterday somehow...
And yeah, definite teenager. Standard logic of "if I break something on your car, then you'll pay for it. And if I break something on my bike, you'll probably pay for that too" which makes perfect sense :confused2
But if it won't end up knackering the boot struts in the long-term then I can live with it, if she insists on being that impatient...
Appreciate1
04-08-2024
McBeemer user avatar
McBeemer
Lieutenant
Poland
268 REP
To save someone searching for something that doesn't exist ... It was only introduced on LCI models ... my previous non LCI F31 did not have the button
Appreciate2
04-08-2024
Pond user avatar
Pond
Colonel
3,126 REP
2.9K POSTS
I only found my internal boot release button the other day when cleaning the interior.
Stupid place to put an 'everyday' switch.
I reckon they should have put it inside the glovebox in the corner, that way it would be even more hidden.
Appreciate0
04-08-2024
V330d user avatar
V330d
Private First Class
37 REP
Not fully correct my pre LCI F31 has the button but does have comfort access, button coded to open and close.
Anyone manually interfering only makes that mistake once
Appreciate0
04-08-2024
Ennoch user avatar
Ennoch
Colonel
2,813 REP
2.5K POSTS
That would explain why I don't recall seeing one then, and as I've been on calls since early this morning I've not had the chance or indeed urgent inclination to go out and check. Slightly disappointing even if I can't think of a single occasion since having the car where it would have been useful!
Appreciate0
04-08-2024
gac user avatar
gac
Second Lieutenant
United Kingdom
136 REP
It's on my 2015 (Dec 2014 build date, I think, so not even close to LCI) pre-LCI without Comfort Access :confused2
Appreciate0
04-08-2024
ade555 user avatar
ade555
First Lieutenant
United Kingdom
184 REP
Not sure how this will help but you can code the boot lid to lift faster when button is pressed, then slow down just before it reaches fully open position, same for closing. I done it on my 4GC as didn't like the thud when closing. Works on X5 so I assume will work on touring.
Appreciate1
04-09-2024
JimmyJab340 user avatar
JimmyJab340
Private
36 REP
Did you know you can open just the glass section of the tailgate for quick access? Manual latch is under the rear window wiper bracket.
Appreciate0
04-09-2024
gac user avatar
gac
Second Lieutenant
United Kingdom
136 REP
Yeah, but because my boot is normally full of crap, I pretty much keep the load cover pulled across all the time so you can't get to anything until you've also faffed about lifting that up into its open position. I find it easier just to open the boot, grab stuff, and push the button to close it.
And I daren't tell her about the fact you can just open the glass cos I've seen the way she slammed my old Megane boot, and I've always preferred my window glass in one piece instead of a 5000-piece jigsaw :D
Appreciate1
